Dual circuit master cylinder
mph
Re: Dual circuit master cylinder
Post by mph »
Im not sure if they make a pull strut but thats another good idea putting one bolt base on the inner fender . If anyone has a old rusty drivers side hinge they want to donate to me ill bolt it on my fb, buy and try a hand full of different length gas struts from Bunnings drill a million holes relocating the strut until something works .im sure it would be sorted in a hour or so once you have all the bits. all the unused struts can go back no worries.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
funkyscooter
Post by funkyscooter »
https://www.gasstrutaustralia.com.au/sp ... on-struts/
These pull instead of push - based on how little the spring moves, not sure if they would work due to minimum travel requirements.
Scott
mph
Post by mph »
funkyscooter wrote:https://www.gasstrutaustralia.com.au/sp ... on-struts/
Nice find. If someone has the spring open and close length based off where you might cut the hinge side spring hooks off and drill in strut fixings and maybe the spring rate tension ill enquire with the company. Im currently unavailable to measure off my FB.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Errol62 wrote:Couple guys I know used XD XE XF dual circuit boosters. No clearance issues to bonnet hinges and work well.
Finally spoke to mates about this. Lengthened XE offset pedal mounted centre of pedal box. No clutch, auto. Suppose could run cable clutch if manual. Booster is mounted central between clutch and brake masters. No hinge issue at all. They didn't think it needed to be &*#@. Also talked about Igor's van using Mazda booster.
mph
Post by mph »
I wonder if thats what this set up is made from then .ImageImage
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Post by mph »
Hi team how would i go about working out what actual size master cylinder i should use for hg front disk and htg rear drums in my fb.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Stock KTG is 1” isn’t it?
mph
Post by mph »
Errol62 wrote:Stock KTG is 1” isn’t it?
Im uncertain thought someone might know. Would the pedal length or throw make a difference to whats needed
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Errol62 wrote: Tue Aug 03, 2021 9:46 pm Stock KTG is 1” isn’t it?
yes.
mph
Post by mph »
Is it an improvement changing to a smaller or larger bore than std. Or just stay with what holden intended and engineered it for.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Smaller bore will give you softer pedal but more travel comes with this. I would use 1” stock one as it is most likely to work with the other stock Holden bits. The only variable is the pedal ratio. I was looking at a HK pedal box this morning. I should have measured the thing doh.
Errol62 wrote: Wed Aug 04, 2021 6:10 pm Smaller bore will give you softer pedal but more travel comes with this.
Yep. Bore size effects how the pedal feels, but less so the overall braking capacity.
Smaller bore = less pedal effort, but more pedal travel.
Larger bore = more pedal effort, but less pedal travel.
mph
Post by mph »
Just had a thought and looked into it seems eh and hr run the brake pedal in the middle of the under dash bracket , i wonder if one of these modded would suit an fb or ek to get the pedal rod moved over to the left allowing to fit a booster directly to the firewall and miss the oem bonnet hinge.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
The pedals on the FB/EK are a simple slip fit on the mounting shaft. They have pretty big bosses on the end. You can dissassemble, grind the bosses down until the pedals move across, then pack the resultant space with water pipe spacers. Worked for me with the wagon.
Cliff Regan
Post by Cliff Regan »
Hi,
I have used the clutch mounting area (auto box) and bent the clutch pedal arm around and welded it to the brake arm.
Just another option I guess.
