Cam's FB Sedan
Re: Cam's FB Sedan
Torana one would be pretty easy to adapt, especially if you are using a Torana rack. Some engineers (not all) will want the breakaway feature built in as well so you can use the standard Holden one already on the column and make a bracket to fit it up under the dash rather than use the FB column clamp.
camstuart52
State: TAS
Re: Cam's FB Sedan
Post by camstuart52 »
Thats what i was figuring. Im assuming even if its a commodore rack you could adapt it to suit fairly easily?
EK JAY
Re: Cam's FB Sedan
Post by EK JAY »
Ht hg column will work aswel and you can keep the ignition on the dash instead of the column
I'm using a ht column shift auto one with torana rack
EK JAY SINCE 1990
camstuart52
State: TAS
Re: Cam's FB Sedan
The ht/hg use a steering box don't they? If so how are these modified to work with the rack? Is your Torana rack standard or shortened?
EK JAY
Re: Cam's FB Sedan
Post by EK JAY »
They do but it's only a shaft that go's from column to box so you just disconnect it and your left with the
Column ready to take the new correct length size shaft and steering uni's both ends eg rack end and column end
I'm using a standard lc Lj torana rack with some extenders I had made up to give me more adjustment on the tierod ends
Check out my thread it's all there :thumbsup:
EK JAY SINCE 1990
camstuart52
State: TAS
Re: Cam's FB Sedan
A little update:
I have been on the hunt and have picked up a trimatic with a b&m shifter, 2700 stall
Converter and transmission cooler. Also obtained a rack to suit the HR front end.
The search continues for a column and a solid 253 runner.
Rear end wise would I be better with an HR or Lc/Lj Torana due to the width?
Are there any tail shafts that will fit between the trimatic and rear end or will I need a custom job?
Re: Cam's FB Sedan
Diff depends on the look you are after, if you want to run dished wheels then Torana, if you are going for the stock look then HR. Tailshaft length will depend on where you sit your motor so best to get one made to suit , you could have a HQ or similar one cut down to suit
camstuart52
State: TAS
Re: Cam's FB Sedan
Yeah I will be running dished rims so I figured the Torana rear will be the go.
Tail shaft wise I'll get made once everything else is obviously in situ. Is there any where to get some drawings/measurements of the chassis kits....not keen on paying that much for one when we can make one?
The parts collection continues.
EK JAY
Re: Cam's FB Sedan
Post by EK JAY »
I think I still have the plans for mine that I made I will have a look
Cost around $100 for the Steel cut to size
EK JAY SINCE 1990
Re: Cam's FB Sedan
send NoMad a PM, he might be able to help you out with a pdf of the bits required :wink:
camstuart52
State: TAS
Re: Cam's FB Sedan
Soooooooo....who wants to punch me first.
I hadnt started the old girl for nearly a month as its living at my mates place temporarily, rock up....connect battery, slight amount of choke, couple of pedal pumps, turn the key and she fires up....purrrsss. I just dont think i can bring myself to rip the old 138 out when its running so well.....
WayneXG95
Re: Cam's FB Sedan
Post by WayneXG95 »
Then don't :wink:
Re: Cam's FB Sedan
if it aint broke dont fix it :wink:
Re: Cam's FB Sedan
A smooth running grey is a very beautiful thing - wont make the hairs stand up on the back of your neck but will calm the soul!! I wont be messing with mine too much - maybe a coat of new paint to make it look new again.
camstuart52
State: TAS
Re: Cam's FB Sedan
Well I've committed to the grey.....twin carbs have arrived, waiting on the air cleaners and extractors to arrive.
I have also ordered some smaller items such as new brake and clutch pedal rubbers which aren't here yet and chrome bullet centre caps which have which will look great. The big news is that the seats have been retrimmed and they look fantastic, not over staged but really nice. They were actually done in a marine vinyl but it's very very soft and should survive punishment well from the kids etc.
During some good weather I colour matched some paint and I have matched in some spots with the patina which blends it all a bit better and is less patchy than it was.....I really like the look.
So fingers crossed I'll get some time in the shed over this Christmas period and have it ready for inspection early To mid Jan.....really can't wait to drive her
Cam
