Stingrays Station Sedan
gday roscorosco wrote:
Are those "Crupi" scuff plates - they sure polished up a treat if they are?
frats,'
no theyre "stingray" scuff plates - was lucky enough to have a good set which I had chrome plated, although they did need to be lead wiped before chroming - a bit thin in places
and the inlays were in pretty good nik also - a nice touch i thought
so.....what are these crupi scuff plates you speak of
regards ray
INVEST IN PRECIOUS METAL
scuff plates
Hi Ray,
sorry for stealing your space here on Your EK.......
I saw stainless plates at Nowra nats and liked the look of them - they are finished in a satin........... but stainless as you very well know is virtually for ever................
I bought a set from Sam Crupi of Shepparton, Vic a few years back with the intention of fitting them when I started work on my interior........
Last year I was between projects and had the bench grinder set up of polishing - just decided to have a bit of a peek at how they would come up.....
After around two weeks, was absoluteley chuffed with them - fitted the inlays and - well, you'll see at Yamba - I believe I have them as good as chrome....
word of warning to anyone watching - please speak with me prior to working the buff on these -
Our old bus was in our treasurer's wedding and Sam was a guest at that - he was impressed with the finish..........
ps - again, sorry Ray - this is your car's post - I'll put one up of my own eventually........
hi rosco
thanks for clarifying that mate, keen to see how yours turned out - hadnt heard of them before
love the chrome, was an easy choice for me
please dont be sorry
our pictures & stories warrant questions, remarks, comparisons etc
so theres nothing to be sorry about
regards ray
regards ray
scuff plates
Hi Ray,
still working in the boot but whilst had the camera out - took these for yourself and Malcolm.................
This is just the overlap portion of the plates - they differ from original in that the just overlap, they do not have the built up "bulge" which creates a cavity.
If you use these, you must change both the front and back on each side.
You will notice the quality of the s/steel - it will buff up beautifully, but we warned - it is very thin and you must be aware of not offering a "leading edge" to the buffer.
It is also important not to over-heat them on the buff - they will distort, I had to "buff" the underside of the first one I did to "bend out" the distortion.
It is also most important that spacers are used to hold up the plate to support it - if not, you will squash them - I intend to fill mine eventually with expanding foam filler - I will lay wax paper or foil to the floor/carpet and allow the foam to adhere to the underside of the plates............
here's the pic.......
thanx rosco
nice work there, they do look like chrome - at a fraction of the cost too, im sure
also more rewarding, as youve done them yourself
i had my exterior mouldings polished, also came up like chrome
sounds like a guy could save some money on polishing, with the right tools of course
regards ray
regards ray
Craig
[quote="rosco"]there's probably more "hair" on my back than my head - I don't know, neck won't go fully around yet and too frightened to look in the mirror............
Tell me about it Rosco Im thinking of doing a comb over with my back hair or just sweeping my nose hair back
Better dead than red
EK, the VN of the 60s
mattymartin
