Moderators: reidy , Blacky
Posts: 14241 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sat Aug 26, 2023 10:41 pm
Then filled in the gaps
Then put the work light in the boot to find the bits I missed and zapped them up
Post
by Blacky » Sat Aug 26, 2023 10:46 pm
Close enough- seam sealer and body schutz will hide the rest
Buzzed up the last of it then had a look above to tidy up the spiders legs
Post
by Blacky » Sat Aug 26, 2023 10:54 pm
Last bit was replace this little section - did a bit of CAD work first
Then cut a bit of tin and clamped it up ready for the glue gun
Zapped up , buzzed the dags off and called it done
funkyscooter
Posts: 708 Joined: Wed Aug 16, 2017 8:12 am
Post
by funkyscooter » Sun Aug 27, 2023 8:00 am
Nice one Blacky. Finding pin holes with the work light is a blessing and a curse. Just when you think you are done you grind and find another. Or move the light and reveal even more.
Scott
Post
by Blacky » Sun Aug 27, 2023 8:22 am
Posts: 11632 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Sun Aug 27, 2023 10:19 am
That’s how it’s done mate. Excellent progress.
Posts: 2691 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Sun Aug 27, 2023 11:17 am
Its a curse, I can't leave it alone until no holes are left.
500 x times glasses and months of practice solves these holey issues !!
Also I find more heat with quick blasts and weld on top of the previous spot half overlapped, like i said months of practice !!!!!!!!
It is coming together although Blacky.
Posts: 2795 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Sun Aug 27, 2023 5:09 pm
Post
by Blacky » Sun Aug 27, 2023 11:31 pm
Bit more today , back on the wires again, not my favourite job
Fitted a deutsch plug to the TPS after having no luck finding a replacement plug to suit -
Then sorted out the radiator hoses - both need a joiner midway , bottom one is 2 separate hoses and top one is a single hose that was the right shape but too short
Post
by Blacky » Sun Aug 27, 2023 11:35 pm
Then onto the bonnet hinges, they were never quite right, the main issue was that they fouled on the subframe drip rails so we made spacers to bring them in a bit which meant the holes didn’t line up so a mod was required
Got it working sort of properly
Post
by Blacky » Sun Aug 27, 2023 11:38 pm
On and off a dozen times or more, close enough now to take the hinges to work for blasting and order some 5/16UNF nutserts
Posts: 4372 Joined: Sun Sep 26, 2010 8:47 am
Post
by Mick » Mon Aug 28, 2023 8:33 pm
top join looks perfect for a TEFBA filter
Post
by Blacky » Mon Aug 28, 2023 9:15 pm
Mick wrote: Mon Aug 28, 2023 8:33 pm
Good idea Mick , when I pulled the radiator hose off it was full of crap and its a freshly built motor with a new water pump, radiator and hoses ........
melly
Posts: 137 Joined: Mon Jan 10, 2022 11:35 pm
Post
by melly » Tue Aug 29, 2023 1:31 am
Good progress Blacky- what type of hinges are they mate and how are they snubbed? looks like a setup like that could fix my fouling issues?
melly
Post
by melly » Tue Aug 29, 2023 1:33 am
Sorry mate now I look closer I can see the pins for gas strut attachments.
