CHOPPED wrote: Sat Feb 24, 2018 9:17 pm
mate im sure i can organise you a t shirt
i know the presedent of the club
i believe hes a bit of an arsehole but i get on with his wife pretty well
president of the year mate
Nathan
Foundation Member
Hey Nomad
Does your master cylinder have 4 pipe positions 2 at the back and 2 at the front if so mate what were the fitting sizes as Im sure yours is almost identical to the one Im going to use and I assume that you blanked one of the back ports as you only need one going to the back?
FireKraka wrote: Mon Feb 26, 2018 11:32 am
Hey Nomad
Hey Neil,
yeah mate i have an XB Falcon Master, the front brakes (rear of the master cylinder) has 2 ports, one at the side and one on the bottom off memory... and the rears (front of the master cylinder) has 2 also... then there's also the port for a brake pressure switch.
i have one brake line from each going to an adjustable proportioning valve, and then one of each blanked off, and the brake pressure switch blanked off since its redundant.
The brake fittings are 3/8" UNF (24 TPI off memory), and as for the blanks i was advised to flare a bit of pipe and use a brake nut, then cut the pipe off flush with the nut and braze it so you don't get any thread leakage and it can lock down tight.
hope that helps mate
Nathan
Foundation Member
NoMAD wrote: Tue Feb 27, 2018 11:35 amThe brake fittings are 3/8" UNF (24 TPI off memory), and as for the blanks i was advised to flare a bit of pipe and use a brake nut, then cut the pipe off flush with the nut and braze it so you don't get any thread leakage and it can lock down tight.
The XA/B/C masters are 3/8-24 UNF, with the long (deep) flare nuts. They are also a funky ball flare (not the normal GMH double flare).
Decided to have a week or 2 off after the nats... but back into it check the list of everything needed for engineering.... so hopefully booking that in shortly...
haha blacky don't stress mate you'll know as soon as its done, i mean half the parts were yours at some stage
but here's a little one from the Nats carpark in the mean time
Nathan
FBOMBED NAts.jpg (363.74 KiB) Viewed 1226 times
Foundation Member
Well everything's full steam ahead on trying to get some plates on the car... off to the engineer on Friday fingers crossed everything's good.
However i did get my Dyno reading and tune that's required... can't recommend Brendan at HBS in Byford enough.
the numbers for those interested... ignore the right column, the red line was the off the trailer at 120, the blue was the 4th pass off memory after a few tweaks here and there
Nathan
FBOMBED 152.9.jpg (1.43 MiB) Viewed 1161 times
FBOMBED Dyno.jpg (731.62 KiB) Viewed 1161 times
Foundation Member
