Gimme 5 years
Re: Gimme 5 years
The grey motor gearbox is pretty easy to work on, isn't it?
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
ardiesse wrote: Thu Mar 25, 2021 7:42 pm The grey motor gearbox is pretty easy to work on, isn't it?
Hi Rob, yeah, it's a pretty simple set up (and I had my laptop in the garage with Harv's write-up :thumbsup: ) Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Finished putting the gearbox together today - clutch kit is in the couriers truck so should turn up next week
gearbox 17.jpg (86.67 KiB) Viewed 784 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I had some left over sound deadener, so while the carpet was pulled back, I doubled up on the front bits
sound deadener 2.jpg (120.58 KiB) Viewed 755 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I ordered the clutch kit from Automotive Superstore because they came up a fair bit cheaper (and I had a voucher from them as well)
...it turned up today in a sealed Exedy box with all the bits
clutch 2.jpg (126.52 KiB) Viewed 727 times
clutch 4.jpg (60.27 KiB) Viewed 727 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I wheeled the gearbox back under the ute today
gearbox 19.jpg (83.18 KiB) Viewed 699 times
and jacked it up to the engine
gearbox 20.jpg (73.69 KiB) Viewed 699 times
before I lifted the engine and gearbox up all the way, I put the driveshaft in and poured about 180ml of SAE90 into the rear extension via the speedo gear hole
gearbox 21.jpg (66.23 KiB) Viewed 699 times
Patrick
Re: Gimme 5 years
That's a handy set up😀
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Brett027 wrote: Tue Mar 30, 2021 7:20 pm That's a handy set up😀
Hi Brett,
yeah, I actually put blocks under the wheels as well to stop things tipping sideways - not too bad with a 27kg gearbox - more useful with a 150kg VW engine.
Patrick
Re: Gimme 5 years
Having a spare input shaft is handy tooooo
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Brett027 wrote: Tue Mar 30, 2021 7:48 pm Having a spare input shaft is handy tooooo
yep, beats making one - there's heaps of cheap plastic aligning tools around for many cars (and lots of kits come with them) but I haven't seen one for a grey - (though it looks like earlybitz has come up with something)
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I put the oil in the gearbox today
gearbox 23.jpg (72.15 KiB) Viewed 658 times
And connected up all the fiddly bits
gearbox 24.jpg (64.21 KiB) Viewed 658 times
I told myself I wouldn't do any work over Easter but I stopped off at Speeds just in case
Patrick
Re: Gimme 5 years
Speeds are the best Patrick! Top service and he has a full set of Rares parts for Holdens in stock. He also has a heap of out of stock things- I picked up the clips for the top door trims last week.
Re: Gimme 5 years
No mess Charlie!
Re: Gimme 5 years
Hi Patrick , what's that steel bolted to the gearbox bottom plate? Part of clutch mechanism?
Re: Gimme 5 years
this is a hotrod so he has a floor shifter
