We buy it on 50m rolls , it’s well under $1 per metre, the cheapest way to buy it at Auto 1 was a little box with about 600mm of the size I needed for $15Mick wrote: Mon Jan 30, 2023 9:25 pmi worked at a place that made electrical connectors etc and supplied heatshrink, when the company changed hands and they had a big cleanup they threw away 2x1 meter cubed boxes of heatshrink of various colours and sizes, i should have taken them and been the heatshrink kingBlacky wrote: Mon Jan 30, 2023 12:31 am Mounted up the relays and computer, ran out of heat shrink so went to Auto One and bought a little kit of it - nearly died when I saw how much they want for it
Red Rattler Revamp
Re: Red Rattler Revamp
Bunnings stocks heat shrink, standing up in a pvc conduit, in 1m lengths. Only the larger sizes (suit 15A and up) but cheaper than those little boxes.
Jcar is reasonable if I recall
But Auto 1 is the only joint open on a Sunday in our neck of the woods and I couldn’t be bothered driving to work to get some
Got a bit more done today, decided to tackle the boot to get away from wires for a bit - had to make a false floor to clear the fuel pump and it’s lines and wires so stopped playing sparky and started playing chippy.
Made a frame out of 35x70 treated pine leftovers from house reno’s
Then cut up a sheet of 10mm plywood to make the top , decided to hinge it so I can use the area for storage
Then got carried away and made a side one as well ….
Then finished off the other side and then cleaned up some quality work in the boot wiring department
Need to run reverse light wiring and sort the fuel sender wiring and this bit can be loomed up and covered with split tubing
Gotta love twisty wire repairs.
I bought The Little One a VL for her first car. It had lots of twisty wire. Every sin that I have committed on a car in my youth have been done to that thing by the last owner.
Figure it's karma that I get to put it right.
I don't do wires this small .................
Got the boot area finished off tonight, pretty happy with how it turned out, a long way from perfect but rough enough for the rattler
Bit of contact cement, of course I cut the first one back to front
Couple of little boxes to hide stuff in
And the fuel tank cover
Nice work mate.
- State: SA
Looks tidy
. Is that the original “short range” fuel tank with updated fuel gauge sender?
