FB ute
Re: FB ute
You might nee to label it mate :roll: :roll:
Re: FB ute
Blacky wrote: Mon Mar 24, 2025 10:05 am
Harv wrote: Mon Mar 24, 2025 6:41 am Very neat, and a hell of a lot simpler than converting another wiper motor. Looks like a real winner for anyone needing to comply with the 2-speed wiper part of engineering.
This is a stock single speed wiper motor but the intermittent thingy will work with a 2 speed.
The only thing i need to be careful of is CEVA workers trying to pull the choke out to start it - that's what broke the original choke cable :econfused:
There is probably enough leeway in the NCOP guidance that the intermittent can be called the second speed. It doesn't say anywhere that the wipers need to be continuous, just that they have to have two speeds and meet at least 45 cycles per minute fast speed, and at least 20 cycles per minute slow speed.
Looking forward to the test-run to see if you can meet those two speeds.
Re: FB ute
Two speed is good but intermittent would be very handy, considering rain in SA is rarely more than a dry drizzle. I couldn’t live without a manual choke though. Considering the low cost, I’ll have to put one on her sedan, which only has single speed EK motor.
Re: FB ute
EK283 wrote:
Errol62 wrote: Mon Mar 24, 2025 7:29 am Nicely done mate.
Just give it as much positive caster and negative camber as you can, and it should be right.
Come on be serious, those cheng shing tyres wont cop the abuse !
I thought he was running wu tangs? ImageImageImage
Re: FB ute
Harv wrote: Mon Mar 24, 2025 11:33 am
the 20 cycles per minute minimum wont be an issue but the 45 per minute flat stick might be an issue ???
Re: FB ute
Errol62 wrote: Mon Mar 24, 2025 5:41 pm
top of the wazza Nankangs from Tarzia mate :ebiggrin: :ebiggrin:
Re: FB ute
Harv, all the engineers i've dealt with won't accept intermittent has to have a switched 2 speeds which sucks because to me it's a ridiculous rule i don't even use 2 speed on the factory cars that have it, i love intermittent wipers
Blacky, bit of masking tape NOT A CHOKE
DO NOT PULL
:wink:
Re: FB ute
When you see the size of the circuit board compared to the choke knob it is a small compact unit. That is a good outcome Blacky :thumbsup:
Re: FB ute
Blacky wrote: Fri Mar 21, 2025 4:57 pm I bought mine from this mob - Image
you bought 3 of them? trying to figure out what it cost
thanks
Re: FB ute
Mick wrote: Tue Mar 25, 2025 10:21 pm
thanks
They were $18 each plus post , was about $70 for the 3 including postage - so $23 each delivered
Re: FB ute
Ended up costing me $37 posted, off US eBay seller. Then I see they’re in Thailand?!
Re: FB ute
Blacky wrote: Tue Mar 25, 2025 11:15 pm
thanks
thanks i thought i was reading it right :ebiggrin:
Re: FB ute
Errol62 wrote: Wed Mar 26, 2025 2:24 pm Ended up costing me $37 posted, off US eBay seller. Then I see they’re in Thailand?!
The ones I bought were in Victoria :thumbsup:
Re: FB ute
I think the one I bought is coming from Thailand :roll: $39.90 has same brand on it in the photo.
Re: FB ute
Ditto mate, but a whole $2 cheaper. I drive a hard bargain!
