Gimme 5 years
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I put the wheel cylinders and brake shoes on
brakes 7.jpg (86.67 KiB) Viewed 786 times
then thought I should re-grease the steering box so I got some semi fluid grease and a dipstick...though I think with grease a dipstick isn't much use until the grease has self levelled (which isn't quick)
steering box 1.jpg (61.55 KiB) Viewed 786 times
I took the top off the steering box, cleaned out as much of the old grease as I could get to and put some new grease in (and helped it along a bit with it's levelling)
steering box 2.jpg (80.41 KiB) Viewed 786 times
while I was waiting for the grease to self level I thought I may as well put the flexible front brake lines in...you'd think that either the hose supplier or the wheel cylinder supplier would provide a copper washer. I noticed this a while back so another eBay purchase took care of that (280 for $18).
brakes 8.jpg (68.85 KiB) Viewed 786 times
I put the hoses and tie-rod ends on and went back to check the grease (I helped it along a bit more with it's levelling)
brakes 9.jpg (82.59 KiB) Viewed 786 times
bled the brakes, decided the grease was right, checked the clearance between the adjuster screw and t slot and put the top back on the steering box...I decided not to put a hole in the brace for the filler because it's pretty close to the top mount and it would lose some strength - (anyway, by rights after I re-check it tomorrow, it's packed for life, if I check the level it will be through the bottom bolt hole and if I add grease I'll take the top off)
steering box 3.jpg (84.13 KiB) Viewed 786 times
Patrick
Re: Gimme 5 years
Nice work Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
trimmed down the brake adjuster hole plugs for the front wheels - by the way - there's even less room in between the front brake adjuster and backing plate - easy to see how brakes can get stuffed by the aftermarket part in standard form
adjuster plug.jpg (57.28 KiB) Viewed 755 times
Patrick
Re: Gimme 5 years
Nice work Patrick
Bargain with the copper washers :thumbsup:
Re: Gimme 5 years
Holdman Restomotive has the original metal type Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I replaced the shackle rubbers and spring pads on the driver's side today. I'd read a few posts about BFHs etc so over the weekend I sprayed penetrating oil on everything a few times (replacing the rubber so didn't worry about it deteriorating from penetrating oil).
It went well - I think when you are doing all of them it makes a difference because you can set it up so there isn't any tension on the joints.
As per the workshop manual, I put in a block of wood and adjusted the jack until I found the spot with no tension so I could pry out the rear shackle (some light pitting but not too bad)
rear suspension 4.jpg (59.78 KiB) Viewed 717 times
I undid the u bolts and rested the spring on the ground so there wasn't any tension on the front pin - gave it a tap and then stuck a small crowbar under the head and slid it out
rear suspension 5.jpg (81.37 KiB) Viewed 717 times
I hadn't bought the bits yet because I didn't know how much would have to be replaced ... all the hardware looked good so I only needed to buy new rubber
rear suspension 6.jpg (96.41 KiB) Viewed 717 times
with the spring lying on the ground, lifted the front up, a bit of silicone spray and pushed the front mounting bolt in (bit of a tap with a rubber hammer)
rear suspension 7.jpg (62.21 KiB) Viewed 717 times
jacked the middle into place and did up the u bolts
rear suspension 8.jpg (55.19 KiB) Viewed 717 times
put the block of wood back in and adjusted the jack until the rear shackle could be pushed in (bit of silicone spray)
rear suspension 9.jpg (59.52 KiB) Viewed 717 times
then took it off the jack bounced it around a bit and did up the bolts - all good but still felt like an extra bourbon
Patrick
Re: Gimme 5 years
Well done. Not a fun job, but rewarding. Those front pins can be a cnut.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Clay - yeah, maybe the penetrating oil helped - I actually got a gyprock saw and cut the rubber back down to bolt before soaking it in the stuff)
rear suspension 1.jpg (68.41 KiB) Viewed 695 times
rear suspension 2.jpg (62.89 KiB) Viewed 695 times
we'll see what the other side brings
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I replaced the shackle rubbers and spring pads on the passenger side today.
The front pin put up a bit more of a fight - I didn't want to hit it too hard so I pressed it out (g clamp with a socket and a bit of pipe on the handle for leverage).
rear suspension 10.jpg (75.37 KiB) Viewed 684 times
The pin looks good - it was just caught on the head
rear suspension 11.jpg (97.81 KiB) Viewed 684 times
One of the rear pins was a bit worn
rear suspension 12.jpg (35.33 KiB) Viewed 684 times
So I went off to the shop
rear suspension 13.jpg (62.83 KiB) Viewed 684 times
All went back together well - finished before lunch :thumbsup:
Patrick
Re: Gimme 5 years
Bourbon o clock came early.
Good idea with the g clamp, and the saw too. I will give it a try.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
for the first time since I've owned it, the ute has brakes, so I moved a couple of cars and drove it up and down the driveway a few times - also the first time it's facing nose up the driveway
Patrick
Re: Gimme 5 years
I love how you’ve put this together your own way Patrick. Very tidy job. Now come on get driving. What else to do mate?
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Clay ... mmm, yeah - what else? and do I do it before or after rego? ... when it's a project I'm more inclined to pull things apart - once I register them - not so much
I've got a muffler and sound deadener coming ... and I'll definitely need tyres
and then there's this lot to think about
to do.png (34.93 KiB) Viewed 627 times
Patrick
Re: Gimme 5 years
No rush mate it’s not ANZAC day yet. Long as you’re mobile for the nats.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
what? this year? :shock: I only started this thread 10 months ago
