My mate just put an electric air cond in his grey powered EK van so never say never
FB ute
Re: FB ute
Re: FB ute
Another couple of pieces to the puzzle waiting for me at work this morning
Re: FB ute
Hi Blacky I'm interested in this intermittent set up, does this go between the normal FB EK on/off switch? do you think I would be able to put it in between the on/off Hi/lo (two Speed) which is the lever on the VT column in Frank?
Re: FB ute
Its a universal jigger mate, will have a play with it this weekend but its basically just a timer and you run a signal wire out of it to your low speed wire or in the case of a stock wiper motor like mine, run from the switch through the timer and then to earth. Will post up more info once I open the thing up and have a play in the shed.
Re: FB ute
Pretty simple wiring , just connect it up to suit your setup
Re: FB ute
I might be able to work that out, being an electrical idiot, but I am keen to give it a go. Looks like I’m on to a belt driven aircon though so may get distracted with that. Thanks for the info mate.
Re: FB ute
For the price on Ebay mate I bought one anyway and as Clay said I can play and see if I can work it out with the dunnydoor wiper wiring in Frank
Re: FB ute
I bought mine from this mob -
Re: FB ute
Well the intermittent wipers are in - pretty happy with how they turned out .
Wanted to keep the dash as uncluttered as possible so I thought I would use the unused choke cable hole - the cable broke years ago - the unit fitted in there neatly and I figured rather than use the knob that came with the kit I would have a go at making the choke cable knob fit the wiper switch
Drilled the guts out of the choke cable knob then broke the new knob to get the guts out of it
Used the brass splined bit - tapped it into the choke cable knob and Roberts your mothers brother
Re: FB ute
Fitted it all up and you wouldn’t know it was there
Finished the brakes off - new hoses and bled them up , need a wheel alignment seeing as I have changed the steering arms and tie rod ends- could probably get away with just setting the toe in
Then made a bracket to mount the cruise control pad next to the column- it clamps in between the dash and the handbrake handle
Blew a coat of paint over it and then blew the froth off a couple ….
Re: FB ute
Very neat, and a hell of a lot simpler than converting another wiper motor. Looks like a real winner for anyone needing to comply with the 2-speed wiper part of engineering.
Re: FB ute
Nicely done mate.
Just give it as much positive caster and negative camber as you can, and it should be right.
Re: FB ute
Now for the proof of the pudding?
Re: FB ute
Come on be serious, those cheng shing tyres wont cop the abuse !Errol62 wrote: Mon Mar 24, 2025 7:29 am Nicely done mate.
Re: FB ute
This is a stock single speed wiper motor but the intermittent thingy will work with a 2 speed.Harv wrote: Mon Mar 24, 2025 6:41 am Very neat, and a hell of a lot simpler than converting another wiper motor. Looks like a real winner for anyone needing to comply with the 2-speed wiper part of engineering.
The only thing i need to be careful of is CEVA workers trying to pull the choke out to start it - that's what broke the original choke cable
