I probably should have rinsed out the container. Just some organic matter.
Sounded a bit rattley when I fired up this morning. Even more than usual. Image
Fitting studs to the cover mounting was another great idea from ol’ gledge. No leaks. ImageImage
I had a listen with a piece of hose to each posi-lock, after warming up and checking they were all tight. I adjusted cylinders 1 and 3 exhaust rockers 3/4 turn preload but really couldn’t pick anything being out. Just the noisiest overhead gear I’ve ever known, since the new head went on. Oh well. Just drive the thing and forget it.
Turn up the wireless 👍
Hah! Prefer to turn up the induction Harv.
Errol62 wrote: Tue Dec 30, 2025 3:47 pm Sounded a bit rattley when I fired up this morning. Even more than usual.
:lol: :lol: :lol: :lol: you're a comedian, here comes another 37 pages of you disassembling half the engine, removing the gearbox and roof lining to track down a rattly tappet :wink: :lol:
Mick wrote: Tue Dec 30, 2025 9:50 pm
:lol: :lol:
Ain’t nobody got time for that…….
Ive got a spare small block chev, no rattly tappets if you need it !!!
Stop teasing me ya bastards! Maybe for the van though Greg…..
This photo with the old ute front and centre gets used every month to promote local coffee and carsImage
Finally got around to painting inside the canopyImage
I need to get it out of the way so I can put in my new bench and cupboard.Image
Got some rubber strips to rest on the tonneau “gunwales”. Image
Probably should let the Epotec cure a while before sticking it down with contact.
Wont rubber rub the paint off ? What about felt or something ????
Time will tell I suppose. It was rubber I took off, so that is what I’m replacing it with. It is a sponge rubber. The tonneau cover has already taken some paint over the years. I have seen others use a plastic film over the paint on some utes, which could be a solution. It will be held down by the fastening mechanism, but that probably won’t eliminate movement. I don’t like the idea of felt as it would retain moisture.
I don’t know why I bought the thing really. It is taking up space, so the solution is to put it on the ute. I will possibly make some timber surfboard racks so I can stick my mal on the roof rather than hanging it out the rear. If I don’t like it down the track I will see if I can move it on.
Made a bit of a discovery when I was painting the inside with 2k epoxy etch. I managed to get quite a bit on the plastic side windows, painting with a 4” brush. I managed to get it all off using gun wash on a rag, before it went off. I expected the gun wash to attack the plastic but it wiped straight off. I think it is Perspex.
you can get clear protective wrap that you could put on the ute where the canopy sits to help paint protection
