Gimme 5 years
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
ardiesse wrote: Tue Feb 02, 2021 6:47 pm The king pin retaining cotter pin is missing on all three (yours with the excess clearance, and the two reconditioned ones).
Hi Rob, yeah my 'spares' didn't have the lock pins - so I took the pin out of the one from the car. Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Brett027 wrote: Tue Feb 02, 2021 6:37 pm Hi Patrick, I tried those Rares reco units too and found that the inner and outer wheel bearing mounts had been machined too much by Rares and the bearings were not a snug fit. There's ways around it, but in my case I decided to put kits through my old ones instead. If you go down that track, reamer is here if you want to borrow it. Brett
thanks Brett, I'll see how I go. Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Hi Brett
so I had to know - I went out to check the fit of the bearings on the stub axles (well, just the side I'm working on now)
with the paint on the axle the bearings don't push on - paint off and all good
Patrick
Re: Gimme 5 years
Great news. I might have got some duds-they looked like they'd been sitting there for a long time.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
a while back someone was selling their stash of control arm nuts bolts, bushes, eccentric bushes etc so I grabbed them
bolted them up with the seals, king pins and some red bits
front end 1.jpg (91.12 KiB) Viewed 644 times
Patrick
Re: Gimme 5 years
Very pretty pat
Re: Gimme 5 years
62ekute wrote: Sat Dec 12, 2020 1:46 pm shortened the tailpipe so I can open the tailgate all the way
Patrick
https://www.legislation.gov.au/Details/F2011C00102
see 10.2.2
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
rainy day but I did get a bit of a chance to tidy up under the guard - took the opportunity to put the brace on while the wheel is off
got the brake shoes ready
brake shoe.jpg (73.82 KiB) Viewed 601 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
In the Shed wrote: Tue Feb 02, 2021 5:54 pm Hmmm.... close but nah, thrust bearing probably collapsed.
Hi Stephen, yep, here's a close up. Patrick
took a few days of soaking in penetrating oil and trying various ways every now and then to get this bush out ... no particular reason for taking it out - just the sport of it
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
spent some time disassembling and cleaning up stuff on the passenger side of the front end and noticed a bit of play in the idler arm support ... so picked up a few more bits for when I put it back together
steering 1.jpg (69.9 KiB) Viewed 556 times
Patrick
Re: Gimme 5 years
The idler arm support seems to be one of the things that gets the most wear.
With the steering box brace, consider putting a hole in it so you don’t have to remove it to check and top up steering oil.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
bit of a slow start to the day but I did manage to put the passenger side front suspension together
front end 2.jpg (75.29 KiB) Viewed 535 times
then I ground down a spare spanner into a camber and castor adjusting tool
went inside and sat down with a bourbon ... but went back out to quickly check all of the front brake bits were ready
brake bits.jpg (127.26 KiB) Viewed 535 times
Patrick
Re: Gimme 5 years
Clay’s hierarchy of king pin wheel alignment
1. Obtain maximum possible caster
Ditto:
2. Maximum camber
3. Maximum upper control arm outer pivot centre height.
Set in that order.
I don’t think it is possible to set enough of either caster or camber in these but then I do like my highway driving and hard cornering. The higher outer pivot lowers the roll height, which results in notably improved handling, so the learned RS tells us.
Nice tooling mod. My dad in laws old crescents fit without this.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Clay :thumbsup:
Re: Gimme 5 years
What Clay said.
I bought a Trojan "stumpy" adjustable spanner, and it works a treat. But the ground-down open-end spanner looks like a proper person's tool.
