Red Rattler Revamp
Re: Red Rattler Revamp
Major panel work there Blacky.
The P76 rotors are still relatively easily obtainable?
Errol62 wrote: Fri Oct 04, 2019 11:17 am Major panel work there Blacky.
Yeah mate you can buy them new either drilled or blank - they are Frod stud pattern in standard form
basic.green
Post by basic.green »
hi mate how did you go with room from front of pulley to rad :glasses:
building the dream Rick
mounted the radiator yesterday , didn't take any pics though - there should be plenty of room but not enough to keep the fans behind it unfortunately
radiator is a VK type crossflow
basic.green
ok thanks good to no.. i have lj torana rad and hoping to get 2 10inch behind but probably the least of my problems. cheers
Got the radiator mounts all sorted out last weekend , filled the last of the holes in the engine bay Image and started mounting the Cortina rack on the front of the crossmember
Sorta forgot to take pics only got these - removing battery bumps
Cut a donor piece out of an old subframe in EKmart
I’m guessing you’ll mount fans in front and modify the bonnet catch. The blower would make it difficult to move the engine back. Good to see you are finding the time, motivation and focus.
Finished the 2 door yet ???
Did a bit more today, got the front end all fabbed up for the Cortina rack and now it's all ready to blast and paint the engine bay and front end
Started the outrigger with a bit of 100x50 RHSImage
Did some CAD work ...Image
Stupid Samsung phone, can only do one pic per post ImageImageImage
Cut RHS like so ,,,,Image
Bent it in like thus ......Image
Tacked it up reasonably straight ...Image
Glued it up .....Image
Made the nose piece much the same way Image
