Cam's FB Sedan
camstuart52
State: TAS
Re: Cam's FB Sedan
Post by camstuart52 »
Certainly doing it properly.,,,and safely but it also isn't going to be show car level.
Good, clean and practical
Re: Cam's FB Sedan
Modifying a pristine, original everything low mileage car might devalue it but not one that needs paint , trim , etc anyway ......
camstuart52
State: TAS
Re: Cam's FB Sedan
Well she's certainly not pristine haha. Just have always wanted a v8 FB, and you can't beat the v8 note.
What floor shift do people use for a T400 etc, something like a Lokar setup?
Re: Cam's FB Sedan
camstuart52 wrote:What floor shift do people use for a T400 etc, something like a Lokar setup?
Easiest way is to run a cable shifter. I run a Hurst on my TH350. Similar products available from Lokar or B&M.
An alternative is to find a factory linkage to suit TH400 and mate it to the early Holden floor pan. A little harder as the cable-option lets you mount the shifter anywhere.
Re: Cam's FB Sedan
why would you want to use a T400 behind a 253 ? Big, heavy , power robbing gearboxes and they wont bolt up to a 253 without an adaptor - go with a Trimatic .
camstuart52
State: TAS
Re: Cam's FB Sedan
I'm happy to use whatever the best options are cause I have to track down a engine and trans yet anyway. I'm assuming I can't go 308 due to the capacity increase hence the choice for the 253
Re: Cam's FB Sedan
You can go 308 within the current NCOP rules... you could even go 327 if you wanted.
EK JAY
Re: Cam's FB Sedan
Post by EK JAY »
Hi Cam
8) I'm doing the 253 v8 conversion in my fb wagn check out my thread on here :thumbsup:
EK JAY SINCE 1990
camstuart52
State: TAS
Re: Cam's FB Sedan
Harv wrote:You can go 308 within the current NCOP rules... you could even go 327 if you wanted.
Oh ok....well that's good to know as it will most likely depend what options appear for sale. Is there any difference between a Holden v8 and a chev and how they fit? Does one fit better than the other or do they both have their own little idiosyncrasies?
I can get hold of a CRS Rack to suit the HR Front end, what's going to be the best column to use to suit it? I'm assuming I'll have to go collapsible?
Re: Cam's FB Sedan
Both the plastic 308 and the SBC have their idiosyncrasies. The SBC fits in OK, but is tight around the fuel pump (swap to electrical pump), and drivers cylinder head (dent the firewall with a hammer).
The CRS rack requires a bit of work to the HR front end... it's not a bolt on job. Whilst the CRS option is cheap, it has a pretty poor turning circle compared to some of the other (more expensive) rack kits on the market. Yes, you will need a collapsible column. You can use LH/LX Torana (as I did), or a number of cut-and-shut options. Alien Retro make a number of columns to suit.
camstuart52
State: TAS
Re: Cam's FB Sedan
So either options viable in there own way!!!
Rack wise what are the other options? I had read the CRS racks had a truck turning circle but I did see the other option that people were using had retired and couldn't find to much other definitive options.
I'm happy purchase the right column to do the job, just wasn't sure if there was a bolt in from a different vintage or a similar cut and shut option.
Re: Cam's FB Sedan
camstuart52 wrote:Rack wise what are the other options?
As far as I remember, Southern Chassis Works, Rodtech, Castlemaine Rod Shop and V6 Conversions all have offered different rack conversions over the years. Some rear mount, some front mount. Big variety in $ and in performance.
Re: Cam's FB Sedan
Mate I have used the V6 Conversions rear mounted rack on my FC Sedan and am doing the same on my FB/EK ute, good turning circle no bump steer but not cheap either.
Neil H
camstuart52
State: TAS
Re: Cam's FB Sedan
I knew the steering was going to be hard but wow.....haha
It's always hard to work out what the best option is budget wise/functionality wise. I think I'm ready to give up and stay grey hahaha
camstuart52
State: TAS
Re: Cam's FB Sedan
How close/easy would it be to get something along these lines to fit with an HR front end and rack? Or am i way off the mark with this column option?
http://www.ebay.com.au/itm/Holden-LH-To ... SwEK9TxyQL
Or is it just as simple to make a factory one work?
http://www.ebay.com.au/itm/ORIGINAL-LH- ... SwnipWU8-W
