Red Rattler Revamp
DaveEK
Re: Red Rattler Revamp
Post by DaveEK »
You have had some really cool ideas…. I like watching this build… :thumbsup: :thumbsup:
Red Rattler Revamp
Didn’t get a chance on Friday to get some steel for making brackets so had a fiddle with the radiator and measured up for fans after chasing an elusive electrical problem with the VS
Want to swap filler and top hose side to side and fit a divider in the drivers side tank - should work out OK , and mount a couple of fans on the front of the rad - only got 40mm of space on the backImage
Gee that left handed upper thermo housing is pretty trick. Prolly make yer fortune selling them on e bay.
Red Rattler Revamp
Got the brake , clutch and fuel lines sorted today, after wasting some time working on a poxy EK Image
mph
Post by mph »
Nice work blacky, must be putting plenty of coffee in those bourbons.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Bump for Marko ......
This may come as a shock , but I did some work on the rattler today ImageImageImage
Got the gearbox back from being beefed up so it was time to finish that part of things off , first thing was modify the base of the short shifter as the US extension housing has a different bolt pattern to the Aussie ones - of course ImageImageImage
Mounting holes got a bit close to the base so had to blow the cobwebs off the mill and whizz a bit out
It ain’t pretty but it fits Image
Next step was cut a hole in the floor and brace it, hole saw sorted the first bit out , then used a bit of CAD to sort the brace out.
Bit of seam sealer and a coat of underbody goo and it’s ready to go back in , except it seems to me I have the wrong throw out bearing, will have to ring the peckerheads at CRS on Monday to sort it out ImageImage
Good work Blacky,
I may have missed it but whats the gearbox ?
Tremec?
It’s a T5
Good to see you are back on the Rattler mate.
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Blacky wrote: Fri Feb 04, 2022 12:59 am Mounted it all up and it works OK Image need to find an opposite handed retainer clip tomorrow then I need to make a mount for the cable and that’s another fiddly job done Image
Blacky is there any chance of getting some measurements of this as I may have to do the same
BILLY BLACKARROW
