Errol62 wrote: Sun Dec 31, 2023 12:24 pm Pumping away and topping up the master on the clutch, only to discover it is leaking somewhere inside the bellhousing.
Oh crap - that blows ........ :shock: :? :thumbsdown:
Me thinks that fool apprentice neglected to tighten the hose fitting.ImageIt's like an 80s disco in there, what with the pretty blue fluid. Clutch and brakes all bled up now.
Cranked with plugs out for about 10 seconds and oil pressure came up to 33.5psi. ImageImage
Bloody hired help Clay hope your not paying him :lol: :lol:
Glad you got it sorted
Yeah - glad it wasn't a gearbox out fix ......
You and me both!
Party time.ImageAll the pushrods are spinning away nicelyImageCam is all tucked up in bed. ImageImage
62ekute
State: ACT
Post by 62ekute »
:thumbsup: :thumbsup: :thumbsup:
gledge
Post by gledge »
Good stuff mate
On the road again ........... :thumbsup: :clap: 8)
Yes! All seems about good. There was some valve bounce around 4000 due to the soft springs. Clutch was starting to present a slight judder, but it works beautifully otherwise. Brakes were terrible until I stood on them hard, and something went pop. They were hard as a rock but now pulling up easily. There still may be some stiffness in the initial application, which I will keep an eye on. I didn't open the VH40 hydraulics up since I took it off the old sedan years ago, but I took off the diaphragm and worked the piston shaft in snd out as it was siezed. These things remain a mystery to me.ImageBumped the idle down to 800. Static timing was about 5 degrees retarded so set to 7 advanced. I noticed the timing varying about 2 degrees, repeatedly retarding every few fires. I noticed some play between the rotor and shaft when I set it statically. I can't imagine what else might cause this unless it is an issue in the gun.
Clay,
It won't be a problem with the timing light. More likely is that at 800 rpm, your centrifugal advance is beginning to operate, which will modulate your ignition timing as engine speed varies. By the way, are you using vacuum advance? If so, disconnect it, and recheck your timing at idle.
I disconnected the vacuum advance when I observed the variation Rob. If it is centrifugal then I’ve set base at 5 degrees instead of 7, so not a big deal. I will send one of my electronic dissys away to get regraphed eventullly.
I changed the oil and cut open the filter. There seem to be dozens of silver specs up to 0.01" diameter but flat.ImageThe interior is all back in place but still pretty raucous in the cab at 100kmh. Image
How come the floor mat is over the kick panels ?????? :problem: :problem:
So the throttle lever doesn’t get stuck under the kick panel when I floor it. I’ve had a few scary episodes lately. I seem to recall a wee tin tab that holds the front edge of the kick board but mine are missing. Also I’ve mucked around tucking it under so many times that the boards are getting a bit tatty.
