Red Rattler Revamp
Re: Red Rattler Revamp
Hey mate there's a wheel missing !!!
Floor pan looks good and original ?
Chugging away, good stuff.
What did you order blacky? Less backspace no doubt. The P76 hubs decrease track don’t they?
Errol62 wrote: Tue Jan 25, 2022 9:04 am What did you order blacky? Less backspace no doubt. The P76 hubs decrease track don’t they?
Yeah , 15 x 6 with a 31/2"backspace. The P76 rotors do decrease track width , they also move the rim closer to the caliper so now a standard HQ rim doesnt fit , I also have a 15"standard Chev rim , that doesnt fit either , needs to have a proper 15"rim centre not a stepped rim.
EK283 wrote: Tue Jan 25, 2022 7:32 am Hey mate there's a wheel missing !!!
Yeah , this car is super solid , surprising when you see the outside of it :ebiggrin:
BS
Post by BS »
Looking good. As others have said looks very tidy underneath. Very cool freshen up
Got sidetracked in the shed today , picked up a motor, gearbox and a Wade supercharger for Craig Allardyce a month or 2 ago , sent him the blower and associated bits , which left a motor and gearbox lying around getting in the way. Was going to whizz the head off and if it was +.060” it was going in the scrap bin as I had no luck selling it or giving it away.
I pulled the rocker cover off and it was as clean as a whistle in there so I yanked the side covers off and it was the same in there so we bolted a starter motor onto it and gave it a compression test which was 110-130 with #4 at 150 so I found a set of manifolds , a carby and a dizzy and we kicked her in the guts Image
Runs like a bought one so will keep the motor and turf the box ImageImage
Then did a bit on the rattler, got into knocking up a throttle bracket ….. did a bit of CAD work then transferred to some patio tube
Chopped and bent , drilled and Linished until I had this ….
Then the boss enticed me inside with steak , veggies and Gentleman Jacks Image , will finish it later Image
FbSTDwagon
Post by FbSTDwagon »
Wicked efforts!
Drew
Orange Betty
Post by Orange Betty »
Am enjoying following this thread, thanks Blacky.
Dave
62 EK Sedan in slow progress
Bit slow this week, new rims turned up today so need to find some tyres tomorrow, and got a bit more done on the throttle brackets
Make it work first then make it neat -
Mounted it all up and it works OK Image need to find an opposite handed retainer clip tomorrow then I need to make a mount for the cable and that’s another fiddly job done Image
Nice one Blacky. If you wanted to make the pivot very precise you could weld the nut to the lever, or cut a thread in it, like a suspension pivot. I know it’s probably overkill.
Errol62 wrote: Fri Feb 04, 2022 8:24 am Nice one Blacky. If you wanted to make the pivot very precise you could weld the nut to the lever, or cut a thread in it, like a suspension pivot. I know it’s probably overkill.
Once its all sorted I am going to machine up a piece of round bar and make a new bracket , that will get rid of all the washers and make it more stable than it is now - need to know its getting full throttle and a straight pull on the cable etc. before making the new bell crank.
FbSTDwagon
Nice creative thinking to get extra leverage on the cable mate, I think I’ll need to be doing similar.
I extended the shaft on the pedal but I don’t think it will be enough to achieve full throttle.
Drew
