WA fb special
Re: WA fb special
This really deserves a separate thread and all goes to Clint. Perhaps we could get s mod to shift it.
I have go agree with you Rob. The holed rim I have here has 85mm b/s for +16o/s.
It's too dark to go fishing in the yard for a non-holed one right now but I recall more like 92mm b/s for a +23mm offset.
Re: WA fb special
$*#@. Apologies to Clint.
Re: WA fb special
Stock HT rims 106mm bzckspace. That is a whopping 31mm positive offset. While they will clear the calipers no doubt, they will be very close to the outer the rod end and upper control arm I speculate. I got a set of 6" with HT centres made up 30+ years ago to be in track on king pin front EK sedan. Later fitted HR disc front and all worked. Excepting that I failed to change wheel nut taper and the centres cracked between the stud holes.
mph
Re: WA fb special
Post by mph »
Hey all good , I've asked the questions and here are the wealthy replies. It don't bother me non guys. But also feel free to move it to a easier to find that topic spot if needed.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
mph
Re: WA fb special
Post by mph »
A bit of colour on the fresh grey my oldmans rebuilding atm.Image
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Re: WA fb special
Details on the paint Clint? I like the shade.
Re: WA fb special
looks like its leaking already :goodd:
mph
Re: WA fb special
Post by mph »
Errol62 wrote:Details on the paint Clint? I like the shade.
I'll ask mate.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
gpi wrote:looks like its leaking already :goodd:
It has one of those low profile Repco heads on it as well Image
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Re: WA fb special
mph wrote: Tue Mar 03, 2020 11:10 am
Nah, it’s a standard head that has been shaved 4” 🤣
mph
Re: WA fb special
Post by mph »
Nah, it’s a standard head that has been shaved 4” Image
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
Out you come temporarily , motor hasnt budged an inch since dropping out the k frame. A few double check measurements and should be good ImageImageImage
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
Found the frame bolts had two parts spacers 4 long 4 short.
2 of the short ones are 18.2 mm two are 20mm. Maybe holden used a blunt drop saw. They all fell out before I could take note came from what bolt. The 4 long ones are different lengths, over all length of the short and long there are all with in 1 mm overall length... or two can be shorter and two longer. I presume they should all be same overall length ?
Rare spares hr front to early holden rubbers are taller at 41mm than my fb ones at 34mm but also squashed for 50 years.
I have to loose the small spacers for either rubber to fit back in with the hr front.
Time for a beer before round 2ImageImageImageImageImage
FB-Special
Big block 161 :lol:
Holley sniper EFI.
BILLY BLACKARROW
Re: WA fb special
Post by BILLY BLACKARROW »
I am pretty sure mine only had 1 piece , I can't tell how long they were now to long ago to remember (DOB sindrome ) DOB date of birth for those who are to young to know. :blushh: :blushh: :blushh:
BILLY BLACKARROW
CHOPPED
Re: WA fb special
Post by CHOPPED »
been a while sinse you played darts im assuming :D
HEY IT WASNT ME
