Got all the bits i need.Image
Invested in some heatImage
out of curiosity, what size did the battery cable end up being ???
Meant to post thisImage
wow - its never going to have volt drop issues :ebiggrin: :ebiggrin: :ebiggrin:
I ran a 50mm in my '57 from the boot and it turned that 510C.I. big block over like the plugs were out of it :lol: :lol: :lol:
Yep that’s the general idea mr b
Made a sort of bus arrangement to locate the switch up under the dashImageImage
Electrical all doneImageImageImageImage
I earthed the starter bottom bolt to the subframe inner legImageImage
Next job mount the battery.
Made up a mount Sunday arvo after club rego dayImage
Now to fix it to the floor.
Meanwhile, clearenced manifold, and mocked up with spacers.ImageMuch better. I fitted 2.25" studs to out the carbys, but had to cut them all down by 15mm, sheesh, all 12 of them!
All the bits are now in hand...... Image
No club runs until September so no more excuses.
Just a thought on the bus. Might be an idea to pull it off and put some heatshrink over most of it. Saves accidently shorting it with a stray spanner (or someones steel capped boots). If its painful to get back out, a couple of layers of PVC tape would do the trick.
Yes Harv. I wrapped it in Nitto tape, then heat shrink OTT. So double insulated. I will also sheath the cable running under the floor mat in heater hose, to be sure, to be sure.....
I've inadvertently shorted so much stuff out that I am damn near giving Jo Lucas a run for his money :oops: :lol:
I'm paranoid about it, don't worry mate...
Got to screw the switch to firewall yet. Modify and reinstall parcel tray.Image
Battery box begone.......Image
Battery mountedImage
Linkage and cable set up connected to the throttle. Pedal feels just about right, more direct than current and gettingImageImage WOT.Image
Fuel linesImageImage
Car Parts Plus got me a Redline reg. Don't want any flooding issues.
