Moderators: reidy , Blacky
Posts: 11469 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Wed Jun 21, 2023 10:30 pm
funkyscooter
Posts: 704 Joined: Wed Aug 16, 2017 8:12 am
Post
by funkyscooter » Thu Jun 22, 2023 7:12 am
They cleaned up very nicely. Interested to know what needles you end up running with. Mine always ran a bit rich. And they were always pumping out dash pot oil. But that has been the same with any SU car I've driven. Kept a bottle of sowing machine oil in the boot.
Scott
Posts: 5695 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Thu Jun 22, 2023 7:30 am
Neat job
(this is your conscience speaking... ram tubes and socks).
Belly760
Posts: 205 Joined: Wed May 26, 2021 9:14 pm
Post
by Belly760 » Sat Jun 24, 2023 2:38 pm
The only difference being you are running a red motor Clay. They might be alright on a red.
FB Ute Stock
EK Ute in Pieces
Post
by Errol62 » Sat Jun 24, 2023 7:10 pm
Yes Sam. I Ike the velocity stacks Harv but not essential or practical.
This cable should do. Isolation switch ordered.
https://www.ebay.com.au/itm/Narva-Batte ... 56-20017-0
Posts: 13984 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sat Jun 24, 2023 8:04 pm
Post
by Errol62 » Sat Jun 24, 2023 9:08 pm
I’ve always chased tractability over reliability over performance over aesthetics. The tripl3 jugs tick all boxes. SU seem to be best value x performance.
Post
by Errol62 » Sat Jun 24, 2023 11:44 pm
I’m wondering where to find terminal lugs to fit the cable. It’s around 15mm diameter. Might have to hit up some HV sparkies at work .
Posts: 2653 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Sun Jun 25, 2023 7:36 am
Mr Clay,
You need the diameter of the copper core with no insulation.
The formular to find the cross sectional area is 0.25 x 3.14 x Diameter (squared).
The CSA then becomes the lug size, or close to it.
Just looking at your cable from the photo its probably 50mm or possibly 70mm.
EK283 on Sun Jun 25, 2023 8:37 am, edited 1 time in total.
Post
by Errol62 » Sun Jun 25, 2023 7:46 am
Cross sectional area Greg? PiR2=154mm2. Primary school geometry mate. Can’t find any lugs that big.
Post
by EK283 » Sun Jun 25, 2023 8:43 am
Clay,
Probably a obvious question, no markings on the cable at all ?
Cut a peice off and take it to an electrical wholesaler, they will have lugs up to 300mm on the shelf normally.
Why are you using such big wire ?
Post
by Errol62 » Sun Jun 25, 2023 8:47 am
It’s is what I have that a mate recommended years ago when I did the sedan. Not an obvious question mate. I will look. Just couldn’t find anything on line.
Post
by Errol62 » Sun Jun 25, 2023 9:06 am
Hmm. Just says Pirelli.
Post
by EK283 » Sun Jun 25, 2023 9:41 am
You need to measure the core with verniers, is it fine flexible wire, similar to welding leads ?
Post
by Blacky » Sun Jun 25, 2023 12:43 pm
The CSA is of the copper only , looks like 35 or 50 mm to me Clay - it should be stamped on the lug that’s on the cable but it looks to be too big for that cable anyway?
