Hi all as you may or may not know I have had a small clutch problem since last weekend and have had to drop the gearbox out ot find out what was up.
It was acting like a pressure plate failure or a trow-out arm breakage...as it has turned out to be a spring from the clutch plate has dislodged itself an wedged between the cluch & pressure plate. I've NEVER come across this ever before? Or for that matter heard of it happening? Point is, I will now replace the entire clutch & pressure plates with brand new ones..
so while I had everything out I've had the advantage of totally cleaning & painting all the bits.
Here's the photo's...
Here's the 'box' just been pressure washed & ready for a coat of grey...
I mark all the bits and clean 'em up on the wire brush on the bench grinder then paint the bits that need it..yes I even wirebrush clean the split washers...?
This photo is for sunny Tim..see ..it was'nt the clutch fork!!
here's the repainted starter motor...I did'nt like it beeing entirely blue!..yuck!...
And here is the repeted photo's from the "D'oh" subject I put up..I'm still at a loss as to HOW this could ever happen???
Scotty.
