Red Rattler Revamp
Re: Red Rattler Revamp
You know the deal - change one thing , you have to change 3 others ImageImage
Finished off the sway bar mounts , then sorted out the ones on the lower wishbones
Out with the old ……..
… in with the new
Then got stuck into the steering stops , had to be removed and relocated to suit the different calipers -
Red Rattler Revamp
Had to improvise with the lower ball joints to set the steering stops up - can’t fit the proper ones until the lower wishbones have been powder coated
Made up some new brake line supports and welded them on -
Then it was time for a beer - back to work tomorrow ImageImageImage
mph
Post by mph »
Wow really smashed out a lot of good jobs mate great work. Tyres normally let you know if you haven't any steering stops.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Tonight was fiddle with the bonnet hinges night , they were close but not close enough, I had to take a few mm off the back of them so they don’t hit the firewall and I slotted the mounting holes to give a bit more adjustment. Also had to measure them up to buy the struts , need to be 275mm open and no longer than 205 closed , and 1000N pressure for those that are playing at home
Stock vs modified hinges
Mounted them up , then trimmed a bit off the front of an old bonnet so I could see how it all worked- it was only an EK bonnet, no need to worry ImageImage
gledge
Post by gledge »
I have been looking for struts for the last hour
gledge
Post by gledge »
Wow I wish I had a bit of bonnet like that mate that would make life way easier....
gledge wrote: Tue Jan 18, 2022 12:47 am I have been looking for struts for the last hourImage
I ordered a couple of pairs today , want me to order another?
gledge
Post by gledge »
That would be great mate or just send me the info and I will just order the same ones.. which ever is easier
Great work and mods there Blacky and that bit of bonnet looks like one I got back from the blasters :crazy: :crazy: :crazy:
Struts arrived today , 2 sets for me and a set for Gledge ImageImage
