Ammo's Ute
Re: Ammo's Ute
Hi Roger;
Yes you are right I had an issue with rotors as you say, this was before I did the VT twin piston caliper conversion, I was running VP calipers and standard rotors, when I bought the drop spindles I had that issue of not enough contact area, when I did some checking I found that the Calais had a slightly larger diameter rotor to standard so I changed to them and it sorted it out, when I rand CRS to find out what was going on they had no idea :roll: :roll:
I run 16" commodore rims as you know and found that I had to run HR steering arms but I also needed to rebend them slightly inwards to get enough clearance.
My rims/tyres are 195x50x16 front
205x50x16 rear
Hope it helps Roger let me know if you want me to get the rotor size for you that I changed to.
What they were like to start with
With new rotors
VT Upgrade
Wrongway Roger
Re: Ammo's Ute
Post by Wrongway Roger »
Thanks Neil forthe refresh on the disc size. It seems the V6 were 270 mm and the V8 were 290mm.
All sorted with front brakes other than the steering arms.
The 16" rim fits and looks ok on the front.
I had another look on the rear and the diff will need to up a long way to sink the tyres into the wheel arch, where they look good.
So far only one tyre dealer has responded to my queries and his select rim is not what I want. :thumbsdown:
The build will go on hold until next month as I'm driving to Perth this Thursday. My old man is not going so well.
Hope to catch up with WA crew.
Re: Ammo's Ute
Wrongway Roger wrote: Mon Sep 12, 2022 5:56 pm My old man is not going so well.
Sorry to hear that mate :thumbsdown: would be great to catch up if you get the chance, I am in West Wyalong working at the moment, not sure when we are getting out of here but hopefully later this week.
Re: Ammo's Ute
All the best with your dad mate.
Re: Ammo's Ute
Sorry to hear about your Dad Roger.
Wrongway Roger
Re: Ammo's Ute
Back from the west and the old man is doing OK, thanks for your comments, guys.
A little more progress on the ute. Will post photos shortly.
Wrongway Roger
Re: Ammo's Ute
I have changed the front indicator to Morris Minor.
Nice glass and smaller.
Front Indicator 1.JPG (290.48 KiB) Viewed 2752 times
Also ordered the wheels
15" x 7 for the front and 17" x 7 for the rear.
Hope to see these in a couple of weeks so I can cut up the diff.
5 spoke grey.PNG (65.04 KiB) Viewed 2752 times
Re: Ammo's Ute
Hustlers
Re: Ammo's Ute
Hustlers, or American Racing Torque Thrust D's?
Wrongway Roger
Re: Ammo's Ute
Wheels are actually a Performance PW100S from Infinity Wheels in Brisbane.
PW 100S.PNG (230.64 KiB) Viewed 2701 times
Re: Ammo's Ute
Different to first photo Rog
Wrongway Roger
Re: Ammo's Ute
I purchase these from Rod Tech from the VN diff.
Bearing carriers.JPG (134.24 KiB) Viewed 2695 times
Gledge suggested these as they are far superior than the factory ones.
With the jig from Gledge, all should line up and be perfect. :lol: :lol:
Come on wheels.
Re: Ammo's Ute
Nice
Wrongway Roger
Re: Ammo's Ute
5 spoke, shiny all the same, Clay :lol: :lol:
I can't reveal all the mods to the ute before unveiling it.
Wrongway Roger
Re: Ammo's Ute
Well the wheel have arrived so now I need to narrow the VN diff.
I should have jumped on it quickly before I had time to think about tyres.
I have now decided to go with 17 x 235 wide tyres on the rear so hence the drive to Clay's for some a quick " mini tubbing meeting".
I was fairly sure I had worked out where to cut but seeing someone else's, just confirmed it.
Started on the hard side due to the fuel filler.
wheel tub LH.jpg (182.16 KiB) Viewed 2635 times
No turning back now.
wheel tub 2.jpg (206.34 KiB) Viewed 2635 times
Now need to cut a strip and weld in the tub
wheel tub 3.jpg (199.73 KiB) Viewed 2635 times
Prenty much a full days work to get it to this stage. RH side will be easier. :lol:
Oh, the hand hack saw is only for show as a 4" and 9" angle grinder does the job. :ewink:
Cheer,
