Red Rattler Revamp
Re: Red Rattler Revamp
Zapped it up and stuck it to the floor
Then we ended up with a shed full of people and much bourbon was drunk and many tales told so no more work was done - there’s always tomorrow
Got a bit done today- went to fit the fan belt and realised the alternator was misaligned by 4mm Image so had to modify the alternator bracket , that burnt up a few hours …. Image
Ended up getting the front of the motor all together , ready to drop the blower on when I find the gasket ImageImageImage
Got the steering and pedals in which is a bit of a milestone, lots of buggerising around to get it all to work - can now finish plumbing up brakes and clutch lines plus run fuel line.
Also spent a couple of hours scraping old window tint off the Commode ute to get it ready for licensing - what a prick of a job ImageImageImageImage
Blacky wrote: Fri Jan 14, 2022 12:53 amEnded up getting the front of the motor all together , ready to drop the blower on when I find the gasket ImageImageImage
The gasket is on the parts shelf, sitting on top of the SMALL shaft pulley...
Blacky wrote: Fri Jan 14, 2022 12:58 am
razor blade and squirty bottle with mild soapy water usually does the trick
mph
Post by mph »
Put a hose in a old kettle secured with a bit of ductape and a brick on the switch and steam the tint off. Nice and dodgy so caution easy to be burnt. Good for getting the tint off though.
Steering set up looks really good mate.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Yeah I was using a steamer - it did help to get the old stuff off but the little side windows are super awkward to access :crazy: :roll:
WesternWagon
Post by WesternWagon »
Tidy work there mate - getting closer
What are you using to secure the bottom of the column ? Im doing the wagon today
Gazza
Member : Holden Car Club WA.
:ASRF Member
Had a productive day today, then knocked off early and had a bloody good Thai feed ImageImage
Work on the engine had to stop on Friday arvo due to not having a base gasket for the blower, so we got into the front end and sorted out all the dramas today Image
Me old mate Brodie came up today to give his opinion on things and he bought some bits with him that he thought might come in handy, namely a sway bar and some fancy sway bar links so we got stuck in and made it fit.
Such a beautiful man Image
Contrary to popular belief, this car still exists…..
Made some sway bar mounts, step 1 - turn 50x50 SHS into 2 bits of 50x25 channel
Step 2 , cut off all the bits that don’t look like a sway bar mount bracket
Red Rattler Revamp
Step 3 , make sure it’s all gonna fit nice and work proper and stuff ….
DImage
Don’t forget to glue a nut in for the bolt to screw into
Tomorrow is weld them in , then start on the sway bar link brackets and steering stops , need to relocate the brake line mounting brackets as well to match the calipers we are now using. Made some good progress today ImageImage
Had a couple of Singah's myself last night. Great work. Had to lower to clear gilmer belt?
Errol62 wrote: Sun Jan 16, 2022 6:47 am Had a couple of Singah's myself last night. Great work. Had to lower to clear gilmer belt?
Yeah , blower drive is close to outrigger on front crossmember - too close to fit a sway bar in between, plus it needed to move forward a bit to clear tie rods on steering rack. Mounted bar upside down and forward - just about to head up to the shed to clean the mounts up and weld them in then start on the links and steering stops.
FbSTDwagon
Post by FbSTDwagon »
The mods never stop when Blacky is on the job!
Drew
