Tidied up the shed and started fitting the roller rockers todayImageImage
Same rocker studs Clay?
Yes Brett, standard 3/8” press in, standard 1.5 ratio, standard pushrods. It’s a mild duration 214* with 0.429” lift, similar to X2 spec. Springs to suit.
They weren’t easy to come by but Wyse Industries came through. They cost me more than the cam, which I got via gumtree. Crow stainless which are half the price of yella terra.
Thank you😀
Fitted ready for adjustmentImage
Mick wrote: Sun Feb 20, 2022 4:35 pm and right on cue :roll: :oops: after being a big mouth i drove to Sydney AGAIN :roll: and in about the last 100ks it's developed a vibration at high speed and not all the time mostly above 100kmh and gets worse it's really bad up round 140-150, getting new rear screen and dual circuit brakes tomorrow so while it's on the hoist will be checking unis etc
2 new unis and all good, though i wish i could get rid of the steering shake between 100 and 120
Some insight in to why rockers failed maybe?Image
That will do it Clay they look like they have had a hard life mate :lol:
Yeah Neil 8 )
Battery got enough to start it so warmed up and set the rollies by ear + 1 turn. Some hassle getting the cover back on with the bigger hardware. The vacuum and fuel lines are close. I’m glad I spaced the thermostat housing out.Image
Snuk out under the radar down the back. Up to 60 on the Speedo a couple of times in second gear. 120kmh which I think is near enough 4900rpm. I’m impressed how smooth it is up there. First time I’ve really been able to appreciate the dough I threw at getting every thing balanced. Never had a sweeter reving six!
62ekute
State: ACT
Post by 62ekute »
:thumbsup: :thumbsup: :thumbsup:
"First time I’ve really been able to appreciate the dough I threw at getting every thing balanced. Never had a sweeter reving six!"
Good to hear Clay- currently spending dollars doing same🙄
Let's see if they can get it right this time...Image
gledge
Post by gledge »
Good luck with that
Well fourth time lucky it seems
Fuk this stupid phoneImage
