Red Rattler Revamp
Re: Red Rattler Revamp
gledge wrote:Looks like we can line up for a race at the nations mateImageImage
I certainly hope so ! ImageImageImage
Just knocked off , was on a march with a horrible fiddly job so worked back and broke its back. Setting up the column and the penetration through the firewall was giving me a headache but got it sussed now.
I made my own collapsible column out of a FB/VK/VN combo and it’s too short to go through the firewall so I used the VL setup but it involves a bit of jiggery pokery- have to fab up a bracket to support the bottom of the column then make a collar for the boot -
The end of the column has a locating tab and a bolt so I made the bracket to suit and welded it to the pedal box , next trick was make a ring to suit the diameter of the collar -
Then make the floor plates -
Then trim the ring to suit the shape of the floor and the bottom of the column collar - I stuck the ring and the collar on the column and through the floor , marked and trimmed it then put the floor plate in to check it until it fit then glued it together
All zapped up ready to cut the hole in the morning Image
Once this is painted up and in it will have steering ImageImage
That’s fiddly alright. Nicely done.
Yes hours of fun !!!!
Just remember that the top mount needs to have slip away tabs to be fully collapsible. I know a lot of engineers let the original bracket hold the top part of the tube but its not right. It needs to collapse toward the firewall, that's how they are designed to work.
Blacky I have this coming up to. I was going to modify/ join the old firewall column plates and weld them straight on to the column ( like the torana column I will be using has ).Breakaway tabs on dash mount. Is this not an option?
I'm not worried about breakaway tabs, the original cast clamp is a breakaway of sorts - it will bust off with a decent hit :D
In hindsight I should have made the floor plate one piece - thinking Mark 2 may be on the cards :roll:
Blacky wrote: Tue Jan 11, 2022 9:56 am I'm not worried about breakaway tabs, the original cast clamp is a breakaway of sorts - it will bust off with a decent hit :D
Ha Ha,
That won't work the second time round, I think to be sure it will be mark 3 !!!!!!!
That's my story most of the time, 3 goes before its right !!!
Good job anyhow Blacky.
Let’s call it Mk1a ImageImage
Couldn’t be arsed starting again so made it 1 piece. Bit of paint and it will do
Terrible paint job , might give it a sand and a repaint tomorrow….
Got a few bits and pieces sorted out today , plus finished the panel work on the console for the ute
No room in the shed for EK’s ImageImageImage
FbSTDwagon
Post by FbSTDwagon »
The problem solving techniques some of you blokes have is inspiring.
My brain wouldn’t know how to imagine such things.
Looking good
Drew
mph
Post by mph »
Some serious work and hours for that. It always looks quick to make or do in photo's but reality and time is much longer. Including coffee breaks. Good effort mate.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Got the handbrake cables sorted out today - after sorting out irrigation dramas at one neighbours place and an air conditioner blowing hot air at another neighbours ImageImage
Was in 2 minds whether to use VK cables to suit the diff or custom made and utilise the standard setup - went with the standard arrangement and custom made cables after weighing up the pros and cons .
Needed to make a pulley bracket to move the passenger side cable away from the muffler - started with this
Cut it out and tweaked it to suit -
