Errol62 wrote: Sat Dec 18, 2021 11:59 amI’m not sure if the roller rockers will fit under a factory cover. I was intending to put one on with 179X2 decal.
You could have an arts-and-crafts day and make up a spacer to go under the factory rocker cover. Ally or PTFE would do it.
Someone on the torana forum cut and shut one but still hit rear valve.
This should look the part.Image
Fitted a passenger side mirror, which is actually just another driver side stalk. Nasco lens would only point down and away from the side, so swapped to another lens wiith more articulation. ImageImage
ekv8ute
Post by ekv8ute »
That’s pretty
Orange Betty
Post by Orange Betty »
Looks great Clay
Dave
62 EK Sedan in slow progress
Thanks fellas. Still may grind the fins off so I can put the decal on.
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Leave the fins alone they look good :vecctor:
BILLY BLACKARROW
OK Billy.
Dropped ute to exhaust shop for rectification.
One of my Sampson's has a slow leak. Turns out the rim has gone a bit porous. Solution is to strip and paint the inside.
Paint the inside of the rim with por15, that will seal it and be hard as nails !!!
I think I will use Epotec Greg.
oz_ek
Post by oz_ek »
Errol62 wrote: Sat Dec 18, 2021 11:59 am I’m not sure if the roller rockers will fit under a factory cover. I was intending to put one on with 179X2 decal.
Any help?..... http://www.kustombitz.com.au/p/4252638/ ... -10mm.html
Thanks Phil, that is a very good idea. Gee the costs start mounting. You know what a Gumtree bargain hunter I am. Alloy rocker cover cost me about $50 delivered.
Column is with Roger Hancock so saving pennies for that at the moment.
Bloody annoyed now as the roller rockers seller contacted me through ebay to say he has cancelled my order. Apparently their stock was incorrect and won't be replenished until February. I was prepared to wait and currently seeking to get the order reinstated.
FbSTDwagon
Post by FbSTDwagon »
Cant contact Yella Terra direct for a set or rollers?
Playing with other brands is touch and go from what I have heard.
Drew
Crow are pretty reliable. What you heard Drew? Yellow Terra are out of my price range.
