the emperor has no clothes
Well here is a cover for his rock'n'rollersImage
Important decision to be madeImage
it almost looks fancy!
put it in that fabulous vapour blaster Drew uses and put some new stickers back on it!
0.429" lift is not overly extreme, more like warm cam... 0.50"+ is not uncommon.
Was it the same rocker-er that busted?
nah he's just a lead foot.
.remember when he told me id been smoking cones because the subframe tubes were different?
Very good question Harv. Different rocker Harv.
Alright then, I might be just a teeny bit, but it’s only my right foot when it is on the accelerator pedal. 8 ‘) 8 ‘)
you can apologise. the mods banned me because of it.
Sorry, I’d probably been smoking cones…………………
8 )
8 )
I wonder if these would bolt up. I'm over the 60 year old pressed steel.
https://www.ebay.com.au/itm/CROW-CAMS-R ... 56-20017-0
I would be checking for spring bind and also for correct rocker geometry - after a coupla cones of course :eugeek: :eugeek: :ebiggrin:
Spring bind would probably lead to bent pushrods before broken rockers though .....
Thanks blacky. I’ll check clearances.
Good price on the roller rockers Clay but are you also going to have to change push rods???
I don’t know Neil. Didn’t think so.
Clearance and geometry all looks good. All oiling well except one, which is still oiling, just not as much as the others. Not one of the ones that has failed. Replaced the broken arm and adjusted all to one turn preload per EH factory workshop manual. They were a bit all over the place, which may have been a contributing factor. Nice and quiet now.
I’m not sure if the roller rockers will fit under a factory cover. I was intending to put one on with 179X2 decal.
