NoMAD's Kustom FB Sedan
Marko
Re: NoMAD's Kustom FB Sedan
Post by Marko »
Nathan,
The serial number on my fans is VA10-AP10/C-61S.
Cheers Mark :thumbsup:
FBVANDAM
NoMAD
Post by NoMAD »
Marko wrote:Nathan,
i believe that would be the exact ones i order... good to know they would well on the 308.
looking forward to checking out your van one of these days its looking good that's for sure!
Nathan
Foundation Member
NoMAD
Post by NoMAD »
Nothing to fancy to add... Got a new shiny wheel just a SAAS classic but feels pretty good
And got my fuel pipe sorted with a non return flap hammered into it since the grade isn't anything too fancy
Which means apart from finishes the boots actually finished
Next is to mount the thermos and work out the bonnet / bonnet catch mods shouldn't be too much effort
Nathan
NoMAD , theres a set of exhaust manifolds for sale in Canning Vale that might work out for you ????
NoMAD
Post by NoMAD »
Really any more info for me on that one?
Nathan
Have a look here cobber ....
NoMAD
Post by NoMAD »
got a little bit of work done on the weekend...
had my under dash panel laser cut out of ally to suit a stereo, gauges, air vents, switches etc.. you get the idea, got it all bent up and had it briefly bolted in.
with everything going on under the dash the air vent pretty much becomes useless, so tacked it shut and it becomes the home for the fuse panel
and took some measurements to start work on the custom sump for the 253
next up is working on modifying the bonnet catch to suit all the stuff up the front. but think i have a solution and then work on the headers since a set of stocky cast ones just don't work on the drivers side... log headers it is
Nathan
Foundation Member
ek amigo
Post by ek amigo »
Hi Nomad Just wondering if you have sussed out the handbrake set up on the Volvo rear end. regards Pete
NoMAD
Post by NoMAD »
I'm using an aftermarket lokar trans mount hand brake... But also there's only a HR diff under here the volvo to be thrown back in later
Try autocables.com.au (auto shades and cables) they make to suit I believe, just tell them what's at either end
Nathan
ek amigo
Post by ek amigo »
sweet as thanks mate
Woody01
Post by Woody01 »
Under dash panel looks good, should tie in with your theme nicely. Can't wait to see those sump mods and headers!!
Woody - UMX-282
FB EK Club WA
Foundation Member # 138
NoMAD
Post by NoMAD »
cheers man...
you and me both, hopefully they don't end up too frankensteined haha
how's northern life treating you? (assuming you moved) and the wagon?
Nathan
Foundation Member
Woody01
Post by Woody01 »
Nothing a welder and grinder can't fix!
Hot up here, but getting settled in, but def missing having the wagon to tinker on. might have to take up fishing or something crazy like that haha
Woody - UMX-282
FB EK Club WA
NoMAD
Post by NoMAD »
I thought you were taking the wagon up with you mate... Maybe you should go get it haha
Well got a bit done this weekend had to do some changes to the bonnet catch looks bit rough and needs some sorting but at the moment it works and that's what matters at this stage, I'll let the photos do the talking on this one
Nathan
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Similar to mine but not as permanent and can be adjusted
BILLY :arrow:
BILLY BLACKARROW
