Chev EK
Re: Chev EK
Thanks guys,
The issue i have is there is no weight on my axle yet so i cant anticipate where the front traction rod bracket will end up.
I can however do some mathematical calculations and get a good indication of spring travel and bump stop clearance, i just need a height as a starting point. The spring retaining plate dosent move in relation to the diff so thats ok to work out, the frontspring hanger however moves up down to the road hence my brackets may be to low if the body is to low etc
Thanks in advance for a measurement that will help me out.
Regards greg
Re: Chev EK
Well another good weekend weatherwise for working in the shed !!
I had to relieve part of my fuel tank to fit the fraud 9 inch, when I first installed the tank it was with the original diff and I just didn't take into account the extra size of the crown wheel :erm: :erm:
Tank fits and all the rear hardware is in, I have to do it this way so I can wheel it around to the paint shop. This still will be a couple of months away I reckon.
Guys DO NOT CONSIDER CUTTING OR WELDING ANY FUEL TANK UNLESS YOU KNOW WHAT YOU ARE DOING! THIS CAN BE FATAL !!!!
Sorry for the warning but it must be said.
Till next time Greg
Re: Chev EK
Great stuff Greg! :thumbsup:
I'm putting in an early 'bags going for a ride in it when you are finished'... :oops: :ebiggrin:
Re: Chev EK
Well guys I must admit the weather is finally closing in ! I hope all you southerners are wrapped up and keeping warm !
Stuffed around as usual in the shed most of the weekend and although it doesn't look much I did achieve a fair bit.
I'm running some holley pro-jection so I had to sort out the fuel line sizes, the breathing of the tank and all the necessary returns and splash restrictors. Actually now I'm typing I just remembered I need to earth the filer neck as it has 2 hoses one on the tank and one on the jag filler cap. Because its built this way and stands alone its susceptible to static and sparks !!! Whoops :shock: :shock:
The projection
The fuel neck with 2 splash barbs and a return fuel line barb and also the pollution attachments that I will be using as a breather instead.
Some rear shots as well as a side shot just to keep the interest going !
Lastly a shed full of shit and a EK Holden :roll: :roll: :roll:
EK JAY
Re: Chev EK
Post by EK JAY »
:thumbsup: :thumbsup: 8)
EK JAY SINCE 1990
Re: Chev EK
Looking good mate, it's good to spend a day getting small things done.
Sent from my D5303 using Tapatalk
V8EK4us
Re: Chev EK
Post by V8EK4us »
looking really good, be interesting to see how the pro-jection goes 8) 8)
mph
Re: Chev EK
Post by mph »
This thing sure is badass
looking good mate
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Re: Chev EK
Well guys,
There goes another year bloody hell !!
I am finally done with my house and holidays and have turned 50 as well !!!
I am honestly sick of looking at other peoples cars so I need to finish the EK this year, this is the goal anyway.
Dragged the car out blew some dust off and got stuck into the lead again, took my time this time and I have mastered it to the point of more lead on the car and less on the ground.
Filled up ok but I have a couple of shallow low spots, I could fill with putty or I might add some more lead, I have got a feel for it now in regards to the melting points and am getting more confident with it.
Any way chop chop I've got to do more so back to the shed I go.
Re: Chev EK
Good stuff mate - keep at it !!
NoMAD
Re: Chev EK
Post by NoMAD »
Looking Good Greg, good to see you back on it.
Nathan
Foundation Member
Re: Chev EK
Thanks for the motivation guys, I do like how you have also stuck to your projects over the long time frames !!!
Got to the shed after work today, bought one of these magnetic earth for welding mate tops !!!!
Ground out about 4mm re welded so the gaps are right, bloody ek is just not consistent with the gaps anywhere !
Tidy up tomorrow then next !!!!!!
Re: Chev EK
Good stuff Greg,
I'll never look at another FB or EK the same after seeing the level of detail you are going to with the panel gaps. It's probably fair to say that GMH had not set up a Quality Team in the early 60's!
Re: Chev EK
Finger hurting time, rubbed all the boot back including all the surface rust and old primer,
Seam sealed
Primed with DP40 PPG
Stone guard and then a coat of Clinker grey, you can really tell the difference between the colours black etc.
I know some people hate stone guard but I like it, looks old and industrial just like the EK itself !!!!
thebrotherj
Re: Chev EK
Post by thebrotherj »
Just catching up on this build now, it's looking great Greg! Kudos for having a go at lead wiping too. Looking froward to more updates :thumbsup:
