WRAY T96 SUPERCHARGER refurb and install
Re: WRAY T96 SUPERCHARGER refurb and install
The moment of truth approaches - clearances all good ImageImageImageImage
I can’t post Vids here but F Yeaaarr!!
Here you go
https://youtu.be/m0yBZgx68WM
Well done that must feel good
Belt tracking is flawless and no touching water pump pulley - if you could imagine a fat man dancing naked round a fire that’s how I’m feeling right now - sorry for the eye burn ImageImageImage
https://youtu.be/dbAJjKD_bIw
Hell yeah 8)
https://www.youtube.com/watch?v=IS7Og1zvdy8
Now wring it's neck and tell me what the boost gauge says :mrgreen:
Boooost!!!
https://youtu.be/_yfuXiX-_-M
Just for Harv - is this any good?
https://youtu.be/lY1lZV8Tc8M
5 o’clock somewhere ImageImage
FJWALLY wrote: Fri Sep 25, 2020 10:09 am Just for Harv - is this any good?
It's showing vacuum at idle (that's normal), then decreasing vacuum under load (that's normal too). It should go above zero though, and into boost, once the revs come up.
Could be the gauge is stuffed, or it's plumbed upstream of the supercharger. Needs to be plumbed between the huffer and the cylinder head.
It’s coming off back of the manifold - Fred seams to think it’s ok and will go positive under load - still bedding veins in also so it should improve with use - it needs tuning also Image
I actually broke your gauge fitting it - housing just crumbled so this is a Garrett brand new
Helps if you grow a pair and close your eyes
https://youtu.be/oWQ2xJlNJro
:thumbsup: :thumbsup: now get it on the street and give it some stick :twisted: :twisted:
Harv if I were to put a Tacho on this what would you recommend considering to will also have the maggy on it?
