WALLY'S EK
Re: WALLY'S EK
Here you go - straight from the donkeys mouth
Battery will be relocated in a couple weeks to make room for the blower ImageImageImageImageImage
Re: WALLY'S EK
Nice, looks neat indeed. Surely that wine can be cured with a good beer :lol:
Re: WALLY'S EK
In the Shed wrote:Nice, looks neat indeed. Surely that wine can be cured with a good beer :lol:
Beer fixes all kinds of wines - good point Stephen ImageImage
Re: WALLY'S EK
Smik looking unit Rob.
Can you explain the advantage in wiring to starter vs battery per conventional?
Clay
Re: WALLY'S EK
Errol62 wrote:Smik looking unit Rob.
Clay
Pretty simple Clay as the starter is direct wired to positive on battery anyway its the same path - dont think there is any advantage
Re: WALLY'S EK
Cheers rob. Aesthetics maybe.
Re: WALLY'S EK
That does look great, clever idea to keep it looking period.
Zero electrical advantage on the starter terminal just looks less busy to the eye.
Re: WALLY'S EK
yes just saves another big wire in the engine bay - I'm going to move the battery to back anyway so will be one wire from back to starter to alternator so it's super neat around the blower.
Errol62 wrote: Fri Aug 02, 2019 9:00 am Cheers rob. Aesthetics maybe.
Re: WALLY'S EK
Battery tray delete - plenty of real-estate there now Image
Re: WALLY'S EK
Interested to see how you are routing cables to rear rob.
Re: WALLY'S EK
Yeah It's a challenging one - I'm leaning towards running it into the cabin just behind the starter motor and along the trans tunnel under the mat then under the seat straight out the back wall - use a couple of nice thick grommets to insulate and then it's out of the weather and free from any potential damage - maybe run a strip of rubber or cover it in mastic for extra insulation from damage from feet etc - the sparky was thinking of running it along the chassis rail but I think it's too exposed and need add a heap more clips etc - the tray will sit in the area between the diff tunnel and the support beam - not directly up against the cabin wall so it has the maximum amount of air ventilation all around it - a lot of free area around there so heat should not be a problem.
Errol62 wrote: Wed Aug 14, 2019 11:12 am Interested to see how you are routing cables to rear rob.
Re: WALLY'S EK
That is what I did in my sedan. Brake and fuel lines don’t seem to get damaged so I thought about following them with the ute. The further aft the battery is mounted, the more benefit to handling.
What about access? I want my tray floor to be watertight so I was thinking of building a box section in the false floor, with latching lid in matching material, but with a drain. There is a plug hole in about the right area. Regarding the air circulation many use a marine battery box. These have minimal venting. Wogked in the daily driven sedan over five years.
Clay
Re: WALLY'S EK
Access for me if pretty easy as my planks are all individual so remove 8-10 screws and I can get into it - I may create some small access cover plates so if need be I can get to the terminals to clean in a rush - not sure yet - if the battery is installed properly with some anti-corrosion paste they rarely need attention - a maintenance free battery is a must so I might look at something a bit fancier than what I have now that looks dont matter and reliability takes over.
Mine will always have the tonneau cover on so water should not be an issue beyond a few dribbles here and there and there is drain holes in the subfloor as well.
Errol62 wrote: Wed Aug 14, 2019 12:45 pm That is what I did in my sedan. Brake and fuel lines don’t seem to get damaged so I thought about following them with the ute. The further aft the battery is mounted, the more benefit to handling.
Clay
Re: WALLY'S EK
I’m sure your sparky has already told you to use a thumping great cable to lower resistance. I used around a 20mm diameter multi strand copper. Can’t remember where I sourced it. Larger output battery also is warranted I was told due to the longer run, but then mine was aft of the driver side rear wheel. You’re right about low maintenance until you need a jump start. Possibly you can get a clamp on the starter nut but need to be careful not to short anything out in the process.
Re: WALLY'S EK
Clay is right !
Bigger cable for the starter current.
Most people fail with the earth return, it needs to be the same size as the battery positive cable. I run 2 earth returns one off the starter and one off the gearbox, makes it al work well.
