Errol62 wrote: Sun Jun 24, 2018 4:38 pmMy repaired tailgate latch Image
G'day Clay,
The tailgate latch has caught my eye. Grace's latch looks like the "stub" of your one (the bit you riveted the extension to), and is a right proper pain to actuate. You have to dig your fingers into the tailgate to grab the stub end. Grace's latch had been painted (perhaps repaired too) by a previous owner. I had always imagined that the "stub" was normal.
Any idea what an original, unbroken latch looks like? (Joe, if your reading, what does your latch look like? Wait.... that doesnt sound right :oops: ).
Straightening rattle rodImageImage
Nice work Clay,
Your tailgate latch lever looks good. That railway iron is very handy. I have a length in the shed too. Mind you I have to make sure I have an extra 2 weetbix for breakfast before I think about moving it cause it's bloody heavy!
I’ve got some smaller bits I use as dollys Stephen
thebrotherj
Post by thebrotherj »
Errol62 wrote:Busted two front indicator lenses putting them onImagePne of these I’ve been saving for 20 odd years. It looked perfect and may have been NOS from memory. Think I’ll just re-instal the buckets with out them.
Hey mate, I think I have a couple of decent indicator lenses, they may get have crazing but I think they’re intact. Let me know, happy to post them to you.
Cheers Joe
Thanks Joe
I have a few more old ones I’ll try. Probably end up buying new ones. I suppose 60 year old plastic is 60 year old plastic.
Clay
Looked on eBay and they’re $40 a pop with gaskets, which I already have.
thebrotherj
Covered in rubber paint, but here ya go:
Cheers, Joe
Thanks Joe. Looks like Grace's latch has busted similarly to Clay's. I'll have to make up a rivet-on extension too.
thebrotherj
Harv wrote:Thanks Joe. Looks like Grace's latch has busted similarly to Clay's. I'll have to make up a rivet-on extension too.
Too easy. I reckon Bill must’ve picked up a good, low mileage tailgate from the wrecker after Leroy was rear ended - it’s entirely rust free and the latch mechanism is un-worn.
*end thread hijack*
Cheers Joe
Clay, the utes as you know are a standard, standards did not have the chrome uprights in the grille so the grille in the ute is correct
Thanks blacky. I’m still learning about these mysterious FB commercial and standard bodies. Explains why my spare grille also lacks the posts. Anyway I like them. The ute will probably get chrome head and tail lights in current configuration as well as stainless windscreen mould, so the posts won’t be too out of place. When it gets painted down the track it may be a different story. The painted dash stays though.
thebrotherj
Errol62 wrote:Thanks blacky. I’m still learning about these mysterious FB commercial and standard bodies. Explains why my spare grille also lacks the posts. Anyway I like them. The ute will probably get chrome head and tail lights in current configuration as well as stainless windscreen mould, so the posts won’t be too out of place. When it gets painted down the track it may be a different story. The painted dash stays though.
My Ute has also received the bling treatment, including chrome dash cluster, from the previous owner. Like you, I’m used to it now, but I’m starting to go the other way! I’ve grown to love the look of painted light surrounds on Standards.
Mine would likely go back to full original if it ever got repainted..
By the by, are you going to try to rub it back to the original Wedgewood blue all over?
That’s right Joe. If it looks too bad I may do a thin coat of closed door enamel or similar but otherwise I’ll probably just buff and wax it. Paint couldn’t look any worse than it does currently.
Speaking of blingImageWibroc side mirror from the stash.
Time for a final underside gurney before I put some wheels on now.
Very flash Clay
Go the Utes :clap: :clap: :clap:
