FB ute
Re: FB ute
Blacky wrote:
FireKraka wrote: Fri Jul 12, 2024 9:33 pm Hey Blacky maybe you need that engine that Brett27 has shown a couple of times :lol: :lol:
It sure is purty 8) 8) but I have one half done in the shed :thumbsup:
Why do I believe this statement 100%?
Re: FB ute
Trev wrote: Sat Jul 13, 2024 7:19 am
The motor in the ute has been crook for 12 months or more Trev, this has just accelerated the rehab program
Re: FB ute
I mean having “half finished stuff in your shed”.
Re: FB ute
Trev wrote: Sat Jul 13, 2024 10:46 pm
:lol: :lol: Oh - NOW i get it :lol: :lol: :lol:
Any idiot can do one project at a time - it takes a special kind of idiot to tackle multiple projects at once :ebiggrin: :ebiggrin: :ebiggrin:
Re: FB ute
Head has been ported and skimmed , valves backcut and ready to reassemble after it has been for a bath
Re: FB ute
Block has been stripped , oil galleries cleaned up and dedagged , honed up nicely which is pretty amazing seeing as its stock bore - now need to find a set of stock rings for it
Both head and block modified to suit a Harv special gasket as well as- found out the stock holes aren’t central to the hole in the gasket so used a die grinder rather than a drill to enlarge them.
The whole lot will go in the robowash tomorrow then hopefully back together on Tuesday night
Re: FB ute
New engine going together- crank is in after much fettling and bad language- my mate who is the brains of the outfit is a Frod guy and he is NOT a fan of rope seals - and he made me VERY aware of that ImageImageImageImage
End float is now much closer to the money Image
Re: FB ute
Good stuff Blacky,
I still have that burning oil smell in my nostrils after the Nats! The funny part was when you overtook in front of me and Mr plod was coming the other direction, engulfed in plume of smoke, didn't even flinch !!!
Could you not modify and replace the rope oil seal ? There was talk on Mercedes or something like that ?
Re: FB ute
This motor has the Mercedes seal in it - had it soaking in oil for probably 3 months but it was still as hard as goats knees ….
FB ute
Bottom end all done today ImageImage
Was scrounging through the shed looking for a timing cover seal and found these old manifold gaskets - probably full of asbestos so they should work a treat ImageImage
Re: FB ute
Deadly!?
Re: FB ute
Good to see you getting the Ute engine back together mate.
FB ute
Loaded her up and took her down for a clean today, took a garage creeper and got underneath and pressure cleaned from bumper to bumper
60Special
Re: FB ute
Post by 60Special »
Great progress Blacky.
The Ute should be ready for next weeks Dunn run at this rate. 👍
Re: FB ute
Finished cleaning underneath today and started getting all the bits cleaned up and ready to refit
Up in the air ready to clean
Bench a bit of a mess
Cleaned up pretty good seeing it’s been on the road for 15 years since the paint was done
