LS1EK
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
I thought valiant were bad with rust. Luckily the seals are pretty solid.ImageImageImage
Sent from my SM-J730G using Tapatalk
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
What has happened here?? Hammer hammer tap tap and it is done just like that. Oh god I Think the rust has got to me.ImageImageImage
Re: LS1EK
That s one place I've not had to repair unless you count swapping entire cowl, A pillars and upper firewall.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote:That s one place I've not had to repair unless you count swapping entire cowl, A pillars and upper firewall.
It looks as it has had a hit. Can you see where it was all bashed in? Bit of surface rust thrown in for good measure ImageImageImage
Re: LS1EK
You have fun with the door to guard gap maybe. When I did mine I fitted guards, then doors, front gap. Then rear gap. Then fitted inner sills.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Another repair ticked off the list. Also dosed the inside of the seals and any other orifice I could get to with rust converter. ImageImageImage
Re: LS1EK
Great work Taz !!
I've said this before but even though my car was looked after the old girl rusted from the inside out !
Just to make you feel better I did the 2 rear floors, parts of the front floors, the bottom A pillars the front floor bracing both sides, both outer sills (thank Christ the inners were ok) The boot floor and seal areas were replaced and the rear right quarter whole. Phew don't really remember doing it all apart from the 5 or 6 years that ticked by !!!
Anyway your progressing great.
regards Greg
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Hope to get the seals finished tonight.ImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
And that is both seals and dog legs repaired ImageImageImageImage
Now to start tidying the body up.ImageImage
Re: LS1EK
Good work on the sills Taz. Tidying, What's that?
59wagon
Re: LS1EK
Post by 59wagon »
Killing it Taz, good stuff.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Rust be gone. Done right using small steel patches.ImageImageImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So time to start cleaning all surfaces. Sprayed all bare metal with paintable rust converter then I will look at throwing some primer on.ImageImageImage
Re: LS1EK
Floor pan looks like how the General should have done it.
What is the paintable rust converter you are using? Does it stick to clean steel? Can be painted over with 2k or acrylic etch prime, surfacer?
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
This is the stuff here cobber.
https://www.bondall.com/ranex-rustbuster/
From memory it recommends to use a oil based primer.
