My bagged EK - Final trim fitted......
RollinLow
Post by RollinLow »
Have you got any pics of the airbag conversion?
wbtonner
Post by wbtonner »
RollinLow wrote:Have you got any pics of the airbag conversion?
Rollinlow,
If you read back thru the pages of this thread you will see pics and details of what EKK001 has done.
FCCOOL
Post by FCCOOL »
paul i will come up for a cruise in the near future, i will be going to the central coast on sunday but you will probably be workng.
Save the big prawn http://www.ipetitions.com/petition/bigprawnballina/
http://kustomkulture.freeforums.org/fc-wagon-with-canted-quads-t14.html
EKK001
Post by EKK001 »
Yeah dude, workin sunday...
We will organise to catch up at a car show in the near future.. keep me posted, hope youre keeping well.
EKjimmy
Post by EKjimmy »
Hey Paul,
Quick question on the flamethrowers on your other EK, what guage wire have you got running from the flamethrower relay box thing to the coil? I've got mine working, but it's not getting enough power to make a spark
Jimmy
wbtonner
Post by wbtonner »
EKjimmy wrote:Hey Paul,
Jimmy
Jimmy
The flamethrower control box only provides a pulsed 12v exciter voltage to the coil and the coil's secondary windings provides the high voltage to fire the sparkplugs, just the same as your coil setup on the engine works. So a standard guage wire is fine.
If the control box is working you should be able to hear a high pitched singing/hum from the box. If this is happening check your spark gaps and coil leads.
Hope this helps.
Woody
EKjimmy
Post by EKjimmy »
got the box working, getting spark, tried gassing it, push the button and pull choke out but i think theres just not enough fuel in there to light up...oh well i got the box bit right considering they try to flog em to ya for $150! $15 bucks worth of materials and it works the same...except i didn't get enough raw fuel through the pipes
EKK001
Post by EKK001 »
You need to make sure the pipes are really hot, when i first hooked mine up i was surprised as to how long they took to get to temperature.. be patient..
If my grey was getting that much flame, yours will definitely follow suit...
EKjimmy
Post by EKjimmy »
okie dokie might give it another shot then. pulled it out for now but i've done it so i can just plug in the terminals. did you need to make it run rich?
also, putting a set on the bagged EK? would look pretty WICKED i gotta say :twisted:
I used to use a little bit of choke and pump the pedal like mad when I flicked the switch.
Worked OK
EKK001
Post by EKK001 »
Yeah, Devilrod has the right idea, pump the pedal like mad with some choke...
Will possibly fit a set on the purple one, not sure if I want to attract any more unwanted attention from local law enforcement...
Might try and fly under the radar for a while... :roll:
EKjimmy
Post by EKjimmy »
haha yeah fair enough. ya think they'd appreciate a nice car when they see one! mine goes too slow to bother the coppers around here
EKK001
Post by EKK001 »
Any help/info appreciated.
Just got the great news that the engine in the EK is cactus.
Anyone looking to part with their 186 or know of one?
Many Thanks, Paul
Also, does anyone know of any EK with triple carb setups?
Stygian
Post by Stygian »
Thommo's FB has triple Strombergs, but it's a grey motor.
NoMAD
Post by NoMAD »
Mez is running triples in his!
NoMAD
