Sent from Cahawba , Alabama
I knew the grinder was doing a good job when my feet were gaining spot burnsBlacky wrote:I like your workboots - same as mine![]()
Swapping the mounts effectively lowers the front of the car another 2 inches or so
Hi mate,CHOPPED wrote: Tue Feb 11, 2020 12:17 am good stuff clint
you know I have a sand blaster at the shop if you need mate
you have my mumber![]()
The red motor was originally bolted to the std 3 speed box which is/was in the "factory" location and motor mounts made to that positionErrol62 wrote: Tue Feb 11, 2020 7:44 am The ek snout happens to fit straight up rivet hole to rivet holes Clint. I vaguely recall reusing all the ek bolts, top and bottom plates, crush tubes and rubbers but it is a pretty vague memory being over 30 years ago. The rubbers don’t tend to wear out generally. If you have the hr bits on hand as well that could be handy just in case.
Luxury to have a bear block to dummy up. Drop a pair of head bolts in the rear holes as this is the interference point with the firewall to floor seam. Clearance between eh sump and draglink is another issue. The rest depends on trans choice. If it is crash box the mods are limited pretty much to fitting front mounts and dealing with clearance to the accelerator bar. You can use the semicircle cutout in the bottom of the radiator opening to line up the crank centreline to the grey motor position. Might need to fit a timing cover for this purpose.
[/quote]
