Starting a reco engine
EKjimmy
Post by EKjimmy »
sounds awesome trev, what you got done to that motor?
EKjimmy wrote:sounds awesome trev, what you got done to that motor?
reco, balanced, bit of a cam (I actually put the whole cam in :wink: ) red motor valves, ported and shaved head.
I think it must be the straight out extractors :roll: , Trev 8) .
FCOV6
Post by FCOV6 »
I'm not familiar with greys but a trick i use on Rover V8's or other engines with external oil pumps is to pack it with as much vaseline as you can then crank without spark, this is usually enough to get the suction going.
TimR
Re: Starting a reco engine
Post by TimR »
Hey guys,
Just priming the oil in my reconditioned engine. Using a 10mm rod, with end profiled for the oil pump, in the drill. I get 30psi no problems, can hear oil moving around. Not getting anything at the rockers. Tried for about 5 minutes.
Do you need something on the end that seals to the block, similar to the distributor o ring?
Grey motor
Thanks
I know you do with a Chev, not sure with a red 6 ???
TimR
Post by TimR »
Thanks Blacky, forgot to mention it's a grey motor
Normally a "drill and rod" will do for a grey. However, the grey motor rockers are fed oil through one of the cam bearings. The bearing has a groove, which is cut for only about 1/3 of the cam diameter. If the cam is rotated so that the groove is covered, no oil gets through to the rockers.
Try turning the motor over 2/3 of a turn (measured at the harmonic balancer/fan), and try to prime again. Remember that the crank turns twice as much as the cam, so the cam will only rotate 1/3 of a turn. If that doesn't work, try another 2/3 turn and prime again.
TimR
Post by TimR »
Thanks a lot, not long to go now!
