They are a Holley part from Redline / HardimanFB MAD wrote:Where did you get your venturi restrictors from Thommo??
All I can find out is that one of the Holley carb models has a venturi that nearly fits the grey carby but can't find out which one??.
part# 14-35 venturi sleeves
The sleeves will need filing down like you would a set of piston rings
to get them to close up a little more. Mine are glued in position with arildite.
Raising the oil pressure simply ensures there is a good film of oil around the rotating parts.EKjimmy wrote:Thommo- what does raising the oil pressure do? is this in a red motor? just curious
Jimmy
When a engine is hopped up, there are higher internal pressures on the mechanical components,
Higher compression pushes down harder on the crank during the firing cycle of each cylinder,
so increased oil pressure ensures the oil is not squeezed out under the increased load.
This is on my grey engine, but it applies to all hotties.
When you hop up a engine, there is two things you want to do
1; Make it go better
2: Make it survive at its new performance level
Jeff
