Turbo time - grey motor
Wrongway Roger
Re: Turbo time - grey motor
Post by Wrongway Roger »
Nice TIG welding. You must have a steady hand and good eyes
Getting close now, injector bungs in and fuel rail dummied up
Just driven a Mercedes Sprinter up the coast and back of WA,
Couldn't here the radio but tuned into the turbo noise, I could get used to that ! MMMMMMM ?????
Craig Allardyce
Post by Craig Allardyce »
I hope you're going to intercool it. The asthmatic grey head will be a restriction that will generate head pressure on the turbo with the resultant heating of the intake charge. Detonation will need to be well controlled.
Another way around the inlet heating is to run water injection. May be neater than an intercooler.
Craig Allardyce wrote: Sat Mar 14, 2026 6:33 pm I hope you're going to intercool it. The asthmatic grey head will be a restriction that will generate head pressure on the turbo with the resultant heating of the intake charge. Detonation will need to be well controlled.
You reckon that will be an issue with only 6-7 PSI of boost mate ????
Craig Allardyce
Also depends on timing, fuel quality, etc. I'd hate to get one bad batch of fuel and hole a piston. If you don't intercool it, carry 10-20% of methanol by volume of your tank. At least you may hear it first, and you could top up with the meth (chemical intercooling as Harv suggests). I'm planning the same with my high comp engine in the FB. As the cam is high lift and minimal duration, my cranking comp is high at 240 psi. Detonation at lower rpms maybe a real issue if the fuel is bad.
Fab work nearly done -
ed.harris
Post by ed.harris »
Burning the Midnight Oil.
All done except for one last bit - it should be here on Tuesday and all the fab work is then finished Image
