wiper motor
Re: wiper motor
Put the first section of the crank on the shaft and connect to the passenger side actuator arm. The crank arm will be pointing slightly above horizontal. Then second not goes on and connect to driver side arm.
Unless I’m mistaken you have it the other way.
Re: wiper motor
I can see your problem Billy but I cant really put it into words, if you have a look at Firecrakas post you can see how the pivot points are all in a straight line with the wiper motor pivot in the centre , yours are on the piss and that is what is giving you dramas
Re: wiper motor
The factory ek ones are on the piss. It is 180 degrees out of phase. That’s what is causing the problem.
EK JAY
Re: wiper motor
Post by EK JAY »
The Crank arm coming off the wiper motor should be at between 10 and 11 o'clock in the park position from memory So disconnect the arms turn it on then off so it parks then undue the crank arm and put it back on at around the 10 / 11 o'clock position then reconnect the arms to the crank and see where the outer wiper arms are on the screen you may have to take them off and reposition them To the park spot hope this helps mate I have done a few conversions and have pics but will need to find them I will post pics later when I find them :oops:
Jay
EK JAY SINCE 1990
BILLY BLACKARROW
Re: wiper motor
Post by BILLY BLACKARROW »
Some photos would help Jay
BILLY BLACKARROW
Re: wiper motor
You need to turn your crank 180 degrees Billy
Re: wiper motor
As Jay says the main arm should be at 10:30 on the clock. Yours in the photo is at 4:30.
Clay
BILLY BLACKARROW
Re: wiper motor
:vecctor: :vecctor: :smile22: :smile22: :grinnn: :grinnn: :clap: :clap: SUCCESS SUCCESS Thanks everyone for your help and knowledge again this forum is so helpfull :smile22: Now can anyone fix my Emphysema??
BILLY BLACKARROW
EK JAY
Re: wiper motor
Post by EK JAY »
:clap: :thumbsup:
As for your other problem :thumbsdown: :(
EK JAY SINCE 1990
Re: wiper motor
tell us what you did to fix the wipers Billy :peaceout:
Re: wiper motor
Glad you got it sorted Billy.
BILLY BLACKARROW
Re: wiper motor
I did what the others said :wink34: the arms were the wrong way around . With the help on here it's getting close .
Last edited by BILLY BLACKARROW on Mon Oct 29, 2018 11:10 am, edited 1 time in total.
BILLY BLACKARROW
Re: wiper motor
Hi Billy I'm about to fit my wiper arms shortly could you please post a photo of what they look like in the correct position so I can get mine right the first time.
BILLY BLACKARROW
Re: wiper motor
I just made them the same as how Errol 62 showed at the start of this topic ,why they didn't park was i put power to the wrong terminal on the switch when i was testing them that's all :smile22:
BILLY BLACKARROW
Re: wiper motor
Thanks Billy
