EK Holden Project Perth W.A
Re: EK Holden Project Perth W.A
Call Tom at Retroblast - 0409 513 458
d1ll1g4f
Post by d1ll1g4f »
Cheers Blacky, have you had work done by him before?
Yeas he blasted my 1 tonner, and my '64 Chev , and the chassis on my '57 - he has been doing it for years and knows what he is doing. He does car bodies all the time.
d1ll1g4f
Post by d1ll1g4f »
Progress to date. Almost completely stripped. Little bit more to do and then she can get blasted.
Sill under drivers door.
Right Sill at Drivers Door.jpg (76.27 KiB) Viewed 3459 times
Left A Pillar
Left A Pillar.jpg (72.92 KiB) Viewed 3459 times
Right A Pillar
Right A Pillar.jpg (65.54 KiB) Viewed 3459 times
d1ll1g4f
Post by d1ll1g4f »
Still got the last few things to pull off the car (brake and fuel lines, wiring harness, heater, windscreen wipers) but thought I would start stripping the rear quarter and see what surprises lay underneath. Does anyone in Perth have the required tools (and would be prepared to give me a hand) to pull the dent out where the bumper bolts to?
John
Post by John »
Keep those pics coming mate.
And for what is worth, go the grey option :)
Drop a V8 into a HK HT or HG ute :) That's what I want to do in the near future.
ingredient in beer
d1ll1g4f
Post by d1ll1g4f »
So figured I'd just give an update on the progress (hopefully not bombarding you all with too many photos haha). Haven't had a lot of spare time over the last month so it's slow going but here's how she sits now. The rear quarters have both had the paint stripped and been sprayed with rust converter/primer.
My old man has been interested in getting involved in the project so he has volunteered to make the rotisserie for the car. As soon as that's finished and I finish the last couple things (remove pedal box, handbrake and dash knobs) it'll go up on the rotisserie and finally get sandblasted.
Lo_maz
Post by Lo_maz »
Good work mate
Look like you and I are at the same stage,ke the pic coming more pics the better
EffBee
Post by EffBee »
Nice work mate, all will be revealed once she's been blasted :shock: :shock:
All the best with the build :-)
Post by Mick Jagger »
man that's rusty,if you aint attached to it,and can afford to I would be searching for a better body to pour coin into
anything is fixable ofcourse,i just ffing hate rust,and once its got it it has it .
don't want to come across as a mean prick,but ive been there before,just trying to save you some time,Cheers :)
kmawic
d1ll1g4f
Post by d1ll1g4f »
EffBee wrote:Nice work mate, all will be revealed once she's been blasted :shock: :shock:
Cheers mate, I'm hoping that the blasting doesn't reveal any nasty surprises.
Mick Jagger wrote:man that's rusty,if you aint attached to it,and can afford to I would be searching for a better body to pour coin into
Haha yeh, thankfully I've got the tools to sandblast so that's at least not going to cost me. If it looks beyond repair I'll start keeping an eye out for another body and use this one for donor sections as there are some really good sections in the body and then there are some shit sections. I've held off investing any real $$ in the project yet until I see what lies under the rust and paint.
d1ll1g4f
Post by d1ll1g4f »
Haven't done much on the car but I thought I'd post the other Body I.D Plate I have to choose from. FB Special - Grecian White Body, Cathay Grey Insert, Mephisto & Chianti Red with Stardust Grey Bolsters
d1ll1g4f
Post by d1ll1g4f »
So my old man wanted to help out on the resto so he said he would build the rotisserie for the car. Obviously not finished yet. Will probably have a Fafnir Bearing on top to make it nice and easy to rotate the car.
While I was on holidays over christmas I picked up a second car. FB Special Sedan. Some of the repairs are really crude so after its been blasted I'll work out if its worth restoring or combine it with my EK to make one good car.
A Pillar Drivers Side
I.D Plate
Adelaide Car
Trim: Inca and Totem Tan
Paint: Grecian White
Insert: Kodiak Brown
kelleigh54
Post by kelleigh54 »
I am with Mick on this one , unless you are capable and have a lot of time and patience the rust repair's will stuff your budget . Also , if you plan on blasting it yourself and your not experienced then you are going to have bigger problem's with the body than the rust . Do yourself a favour and spend some money on a good shell as it will be cheaper than your rust repairs . You will save yourself a lot of time , money and heartache which will end up being an unfinished project that has sucked you dry .
In regards to a previous comment when you were thinking of installing a T56 . You need a lot more room than the auto tunnel can offer . Stand a better chance of fitting 9 stubbies in a 6 pack carry bag .
kelleigh54
Ooops ! just picked up on the fact that your post was January 2015 not 16 . Oh well , I guess your a little wiser from your experience by now . And I don't mean that to sound disrespectful . For your sake , I hope all is well .
