My FB wagon
ben
Re: My FB wagon
Post by ben »
:thumbsup: nice work. Good to see another one being saved
Grimbo
Re: My FB wagon
Post by Grimbo »
Thanks for the positive feedback guys, I haven't had much time of late to work on the FB. But found a little time last week and an hour this arvo and this is what I accomplished.
The left hand inner sill where the subframe bolts up was pretty rotten, so cut it out.
Made a new section from 50 x 75 x 3mm RHS and welded into what was left of the old section. Then positioned it correctly and welded it in.
A bit more progress :) , now to bolt the subframe back on again and repair the floor cross member that takes the two inner legs of the subframe.
Sam
wot179
Re: My FB wagon
Post by wot179 »
Good stuff.
Turn the heat down just a tad on your welder.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
FATBOY
Re: My FB wagon
Post by FATBOY »
Nice work Sam
Grimbo
Re: My FB wagon
Post by Grimbo »
wot179 wrote:Good stuff.
Why is that? I always lean towards too hot rather than risk lack of penetration. In saying that I had the welder set on 6 which is the highest setting on my transmig 195, but I do suffer a bit of voltage drop as I have to run it off a lead from the house (no power in the shed). Probably should play around with it a bit more, lower setting and weld slower to get the right penetration. I'm not as well practised as I used to be.
Sam
Grimbo
Re: My FB wagon
Post by Grimbo »
FATBOY wrote:Nice work Sam
Cheers mate.
Your alive? I thought you'd dropped of the face of the earth.
Re: My FB wagon
cool :thumbsup: glad to see this going forward
oldnek
Re: My FB wagon
Post by oldnek »
Sam
I'm with you Sam, the more heat = the more penetration in these structural areas. Be different for panel steel as you'd be worried about distrortion
Tim
I totally agree, I wouldn't even turn it down for panel steel. Better penetration less grind clean up and distortion.(Distortion only comes from the panel shrinking after you weld and if you lay up then shrinking becomes more prevalent, only to find you have loads more grinding to do to dress it up). There's nothing worse to see weld bead layed up on a job then you grind it down to see a partion line (no penetration, no point in welding)
Those welds are pretty good Sam. Good job Mate. :thumbsup:
wot179
Re: My FB wagon
Post by wot179 »
Have a look at your vertical welds.
They are hollow in the middle.
The filler metal is rolling down and pulling material down with it , preventing penetration as you race down to stay in front of the filler metal.
The weld will be sitting on top instead of penetrating as it should.
More heat doesnt necessarilly mean more penetration.
The plug welds look fine,its the vertical down welds that need you to modify your technique.
I suspect your gun angle is wrong,too.Dont angle it up so much,keep it closer to horizontal.
Just trying to help.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
FATBOY
Re: My FB wagon
Post by FATBOY »
Still around Sam have had plenty on my slate for the last 6 plus months but still plugging away on the moon ute
Grimbo
Re: My FB wagon
Post by Grimbo »
wot179 wrote:Have a look at your vertical welds.
Thanks heaps for the feedback, I see exactly what you are saying in regards to the vertical downs. I really appreciate the advice/help.
Thanks :thumbsup:
Re: My FB wagon
Good n solid now :thumbsup: Keep chipping away Sam :)
Stewart
Grimbo
Re: My FB wagon
Post by Grimbo »
Way too long since last update. Haven't done to much but it's slowly moving forward.
The floor member that takes the subframe y legs was cactus the whole way across from one sill to the other. Luckily my old donor EK wagon had a reasonable one except for the passenger side. I repaired the rust, bolted the subframe up and welded it all back together and managed to do the first floor pan.
Here are the pics
What I started with.
Floor member from donor, 3mm plates to sleeve the repair section plug welded in.
More rust.
Cut it out.
3mm Flat bar repair.
All back in.
Floor pan.
Sam :)
EK JAY
Re: My FB wagon
Post by EK JAY »
nice Sam will be solid as a rock now mate :thumbsup:
EK JAY SINCE 1990
Re: My FB wagon
Nice work Sam. :thumbsup:
