I managed to get the second strengthening plate welded on to the subframe during the week and put rust converter on it.
Only had to die-grind the single bolt hole on the leg of the plate a little to make them fit properly michaeljohn1234m which was good.
Pulling subframe out of the shed so the little fella could help blow it down allowed me time to clean up the shed a little.
Pulled out the spray gun yesterday afternoon and put a coat of KBS chassis gloss black on it.
After so many hours cutting welding and grinding, you get a fair kick out of putting some colour on parts
Will put a second coat of paint on this arvo.
Anyway, check out the pic's.
Little Helper, he wanted to work on the tractor in the background but the air hose wouldn't reach that far!!
