'57 Chev build.
Malcolm
Re: '57 Chev build.
Post by Malcolm »
That is fantastic, considering now I've got the very same type of car in my shed as my next project.
Question - what did you do with the front you cut off. I'm chasing the RH front rail that attaches to the cross member. Do you still have the front and if so will you sell it.
mal
Malcolm W.
Re: '57 Chev build.
Youre lucky Mal , its in the trailer ready to go to the tip. Send me a drawing of how much of it you want and I will cut it off for you.
Malcolm
Re: '57 Chev build.
Post by Malcolm »
Mate that would be great.
What I need is the RH front rail end that attaches to the crossmember.
Hard to explain but I'll give it a go, the rail end is attached to the crossmember in two areas and looks like a Y piece. The end of the rail is where the bumper bracket bolts to.
What I need is the whole Y piece, and if it can be cut out of the cross member so I can unpick it and reattach it to my crossmember.
I will pay what ever it takes if you can do this and post it to me.
Mal
Malcolm W.
Malcolm
Re: '57 Chev build.
Post by Malcolm »
Hopefully this works, but this is the bit I need
All of this Y piece cut out of the subframe so I can unpick it and put it onto mine complete
Mal
Malcolm W.
Re: '57 Chev build.
No worries Malcolm , PM me your address and I will get it happening for you.
Malcolm
Re: '57 Chev build.
Post by Malcolm »
Hey Blacky,
What engine mounts do you use on the side of these engines. I got a 1991 Gen 5 454 BB for my 57 but has no side engine mounts. Are all chev mounts that bolt to the block the same.
Mal
Malcolm W.
Re: '57 Chev build.
I used HT 350 mounts on the block then made mounts from RHS once I was happy with where the motor sat. You need to dummy fit with a distributor to ensure adequate clearance to the firewall.
Has that bit of chassis turned up yet ???
Malcolm
Re: '57 Chev build.
Post by Malcolm »
Thanks Blacky,
Nothings turned up yet, but Im shore it will.
I've see a few different types of HEI distrubitors on ebay, new starting at about $65. Can you advise what difference there is or a good brand, vacume advance or not. I didn't think you could buy anything for $65 these days.
Mal
Malcolm W.
Re: '57 Chev build.
I have a MSD setup in mine , with the ignition unit and coil mounted up under the dash - dont buy Procomp gear - its sh it.
A coil in cap type stock distributor should see you right.
Re: '57 Chev build.
The video of this weekend is FINALLY ready ! Vicky , who did all the filming and editing and whatever else is involved in making a video happen , was crook for a while but now all is well and the DVD is available 8) Watched it this weekend and is good for a laugh or 2. 8)
samprinci
Re: '57 Chev build.
Post by samprinci »
WOWWWWWWWWWWWWWWWWWWWWW.
Congarts. that's freaken AWSUM!!!
www.fbekholdennsw.com
Re: '57 Chev build.
NoMAD
Re: '57 Chev build.
Post by NoMAD »
nice work Blacky, good to see it finally done... i so need this done to my FB... :oops: :oops: :oops: hahaha
will have to nip down to AAP... man i always spend money there
have you actually fully finished this thing yet? or what have you been working on now?
(will try and get up your joint Sunday arvo perhaps this week if available for those parts, otherwise it can wait)
Nathan
Foundation Member
Re: '57 Chev build.
Blacky,
I must say I live in Sydney as you once did and this sort of caper is hard to come by !!!!!!
Good luck to all of you involved in that club, I wish I could be part of it.
Re: '57 Chev build.
I just watched the video of this again last night - holy hell that was a big weekend , wish I still had the energy level I had back then :? :?
