Went in easy with all the original bits minus bottom rubbers and tubes as I always thought. All the tubes are the same length. Rubbers nipped up nicely. Beer o'clock.ImageImage
they are not...
that is what we are saying clay...
Not sure what you mean guys. Rubbers are all compressed up as they were with the original front end. Same as what I did in my last car and that went from pillar to post over a decade, around the clock with no issues, this same front end.
Achtung baby. Happy Anzac Day.
It were on spesh.Image
62ekute
State: ACT
Post by 62ekute »
Errol62 wrote: Fri Apr 23, 2021 5:31 pm Went in easy with all the original bits minus bottom rubbers and tubes as I always thought. All the tubes are the same length. Rubbers nipped up nicely. Beer o'clock.
cheers :thumbsup: :thumbsup: :thumbsup:
Couldn't resist a mock up. Front sill 205mm, rear 225mm. 185/70 fronts, 235/60 rear, gearbox, block and two bare heads up front. I will fit some taller front tyres and should be good.Image
Hurriedly Rectified Rob no doubt given up on me since I chopped the springs.
I'm pretty happy with how the stance is turning out. Could be lower but guards will be pretty well filled and no rubbing. Well we will see about that.Image
Great photo Clay. Love it😀
Cheers brett.
Pulled sump and backing plates out of the citric bath, cleaned, prepped and primed.Image
Then got the brush out and gave the front suspension and splash pans a coat of chev charcoal engine enamel.Image
62ekute
State: ACT
Post by 62ekute »
looking good Clay :thumbsup: - I kinda thought you were about finished at around 160 pages ... but nah
Looking good Clay, that citric acid is certainly the go. How far away is the reconditioned donk?
62ekute wrote: Sat Apr 24, 2021 7:16 pm looking good Clay :thumbsup: - I kinda thought you were about finished at around 160 pages ... but nah
It's the project that just keeps giving!!! I'm glad 'cause there's lots to learn from it for me😀
I just go on and on......
Expecting motor back next week Stephen, ready for assembly. Should have suspension and brakes sorted prior barring any surprises with the calipers.
[/quote]
:thumbsup: Good job
Calipers are stripped and marinating in bucket of citric acid. One of the pipe ports was chewed out so replaced half shell from spares. I remember shearing off bleed screw on the same shell In ‘86.
Painted backing plates and other bits with the grey gloss enamel. Brush is just as good finish with this stuff, easier and more economical.
