- Screenshot_20210415-102412.png (164.19 KiB) Viewed 904 times
too right
Made it home. So did these.
I hope your chooks turn into emus and kick your dunny down
Bit of tweeking got mounts sitting nice. Spigot, journals and subframe notch all line up. Kudos Pete and Neil.
Beer now, weld tomorrow.
Mounts are all but hanging over th e back of the crossmember. I thought I was going to be moving them forward as previous car was close to the firewall as the lip needed to be removed from the cowl to firewall seam. I did change engine mounts to some reinforced "XU-1" type.
Then there is this older style mount
Loving you
Isn't the right thing to do
How can I ever change things
That I feel
That I feel
Don't know but a melody would help
go your own way
Then play on
Heroes are hard to find
Hi Clay using those remade mounts is the only way in my book I've seen some really shoddy ones that just dont look safe.
Before my FC was a V6 I had a 208 and 4 speed in it and when I moved the mounts for it the were right at the very back so I would expect the same for you.
Thanks Neil. The two grey gearbox mounts take a lot of the weight so the fronts aren’t working too hard weight wise, although they will take a fair share of the torque when the right foot goes down. I may change to later box at some stage in any case. I believe red crash box will fit with relatively minor massaging.
Pulled finger out, welded mounts, cleaned, ranexed, primed and covered with remaining 250ml kbs moter koter Chevy charcoal grey.
- State: SA
