Ammo's Ute
Re: Ammo's Ute
Any chance of a rear view for the arse men?
Re: Ammo's Ute
Looks a bit like the FE / FC, either way it looks cool. Once the folk at A Class have done their bit it will look fantastic!
Re: Ammo's Ute
nash ambassador
Wrongway Roger
Re: Ammo's Ute
Post by Wrongway Roger »
Correct - Nash used these on various models from 55 to 59.
Wrongway Roger
Re: Ammo's Ute
I got stuck into the fuel tank today and OMG.
Firstly the tank purchased on Market Place with the seller telling me "mate, good tank no holes". I call BS as I hade the tank grit blasted and found a number of holes. :evil: :evil:
Holes 1.JPG (94.33 KiB) Viewed 1397 times
Holes 2.JPG (93.5 KiB) Viewed 1397 times
Next the tank is wider than the opening in the ute and wider than the rails.
The nuts on the spring hanging are on the inside, for neat look, which now need to be reversed.
Cut, cut and more cutting, grind cut and grind again then finished with a little shaping with the BFH and it is nearly in.
Old tank out.JPG (108.1 KiB) Viewed 1397 times
hoe cut.JPG (121.88 KiB) Viewed 1397 times
tank in.JPG (103.04 KiB) Viewed 1397 times
AS you can see the edge of the tank overlaps the rails.
I will be building a frame to sit it on with nut serts
In retrospect, it would have been easier to cut the original tank in half, add a section and weld it up.
Possibly used a sedan sender.
Another option could be early model F*#@D tank as they may be a little narrower.
Currently on my 3rd beer.
Re: Ammo's Ute
wow. the long way.
Re: Ammo's Ute
That is a bit of a pain in the butt Roger. What is the plan to seal the tank? Maybe a two part tank lining epoxy compound?
Re: Ammo's Ute
Taking the easy route again, I don’t know………
Wrongway Roger
Re: Ammo's Ute
Steve, I will weld the holes in the tank via bronze weld so I can control the heat.
It's a normal thing with modifying a car, one change leads to a couple of other changes that lead to more changes.
In this case a more measuring of the tank but I will over come the issues and finish it off.
Re: Ammo's Ute
Mate a brand new Mustprang tank is only a few hundred bucks and they fit nice , just don’t have the spare wheel well
Re: Ammo's Ute
Hey Roger that's a shame mate but I'm wondering if you want to sell the bit you cut out mate I could use it for my wagon 😜😜😜 bring to Nari mate and I'll slip it into the back of Frank for the trip back across the paddock 😂
Re: Ammo's Ute
Sounds like a plan Roger, could also silver solder?
Re: Ammo's Ute
Yes, or just plain solder.
😁Just as a matter of interest and without meaning to hijack the thread, I have a nice bright shiny Mustang tank if someone in southern NSW is looking for it.
Belly760
Re: Ammo's Ute
Post by Belly760 »
Brett027 wrote:Yes, or just plain solder.
ImageJust as a matter of interest and without meaning to hijack the thread, I have a nice bright shiny Mustang tank if someone in southern NSW is looking for it.
Yes please. I’ll take it.
FB Ute Stock
EK Ute in Pieces
Re: Ammo's Ute
It'l be buyers premium for you mate🤗
