Moderators: reidy , Blacky
Posts: 1833 Joined: Wed Nov 11, 2015 4:54 pm
Post
by FJWALLY » Thu Apr 01, 2021 9:45 am
Errol62 wrote: Believe me I tried blacky. The rubbers are 10mm longer than the space they have. This was only way I could get nuts started. Wound them up to 30lb ft which was as much as I dared. Then took up with bottle jack and wound some more. Will have a good idea of the ride height soon.
Are they the right rubbers? Mine didn’t have to compress that much - bit of rubber grease and they tapped in nicely and only locked up with the final compression as nut locked up - were they rare spares?
Posts: 11698 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Thu Apr 01, 2021 11:02 am
They are in and all good. Not Rare Spares. As they say in cherman, they are nizentite.
Post
by Errol62 » Thu Apr 01, 2021 3:00 pm
Might trim these
Post
by Errol62 » Thu Apr 01, 2021 3:40 pm
Better. Taken 4mm one side.
Posts: 2294 Joined: Wed May 16, 2012 10:18 pm
Post
by In the Shed » Thu Apr 01, 2021 4:33 pm
Good work Clay
How is the engine recon going? Did they say when you might get it back?
Post
by Errol62 » Thu Apr 01, 2021 4:37 pm
Moment of truth. If anything I would've liked it lower but still got spare, floorjack etc. Oh and the motor and trans.
Post
by Errol62 » Thu Apr 01, 2021 4:45 pm
Hi Stephen
They were on to it on Monday when I dropped the head off.
Plenty to keep me busy here. Wheel Cylinders turned up in the nick of time for Easter. Spring bolts were too late.
Will hang shocks and put floor back first.
Post
by Errol62 » Thu Apr 01, 2021 6:58 pm
Rear brake lines came out well but then I've had a bit of practice now.
Post
by Errol62 » Thu Apr 01, 2021 7:04 pm
This is my spare now to suit the HR brakes. It's like a lucky charm to me. It came with the disc front I put in my old sedan (Errol) in 1986 and been my spare ever since. The rubber looked old then. It's a Uniroyal 240 steel radial about 1978 era.
Post
by Errol62 » Thu Apr 01, 2021 7:27 pm
Had to play around and put the dish pigs on. Very close too her guards but drums aren't on yet. Just glad I've got a decent sway bar on it.
Posts: 14319 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Thu Apr 01, 2021 11:31 pm
good thing you dont have drums on it going by the last pic ?? looks like outside tyre will rub when cornering if they were that close to the inner guard
Post
by Errol62 » Fri Apr 02, 2021 12:29 am
There will be some fiddling with rims and inner guards may have to cop some adjustment
Post
by Errol62 » Fri Apr 02, 2021 9:04 am
Tyres are 235 and outside clearance horizontally is about the same as inside, although at current ride height there is plenty of vertical clearence.
Posts: 1131 Joined: Mon Apr 26, 2010 2:08 pm
Post
by gpi » Fri Apr 02, 2021 1:42 pm
is the sway bar on right?
Posts: 2718 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Fri Apr 02, 2021 1:59 pm
Sway bar links too long brother or not connected yet !!!
Your gunna need bigger tubs or smaller tyres.
