After 000 steel woolImage
Stickers ImageImage
The SA car club one is a beauty. I guess there will be a 'Life's a beach' one soon?
Go Clay🤗
Wrongway Roger
Post by Wrongway Roger »
Well done on the club sticker on the rear window. I knew you would have no problems after your build.
Was s challenge Roger. Th asnks for th e heads up. Brett it's a nice sticker. Not normally in to stickers. Not life is a beach, maybe old guys rule.
Not a fan of stickers either, though one of the "classic, not plastic" ones would suit.
Need this one -
Yairs!
Mucking around on Friday night. Deliberately loading up the rear. Half tonne load estimated. Still got 3" to bump stops and the spring is flat. Front sits 8" to bottom of sill, unladen 8.7". Rear 7.9" laden, 9.7" unless . 1.8" lowered rear.
The 215 65 14 tyres interfere with the guard by a few mm. New rims will be 5mm less offset, and run 205 60 or 195 65 14. Should be able to get it lower still. Just waiting until after Charmaine's "mystery" cruise next weekend, then I'll pull the rear out and replace the springs.ImageImageImage
Ute been in the naughty corner since last weekend when the inside drivers door handle popped off outside the bakery how embarasing. After trying different handles and clips, changing cranks and chopping down the spring still no luck.
Re set clip spring in the vice and all sorted!? Next time I'll do that first.
Errol62 wrote: Sat Feb 13, 2021 4:46 pmRe set clip spring in the vice and all sorted!? Next time I'll do that first.
Some clips seem to be spring steel (like a bulldog clip), others seem to be chrome plated mild steel (as rigid as trifle).
https://www.ebay.com.au/itm/292771293181
Patrick_R
Post by Patrick_R »
Whoops.
That’s a bit embarrassing mate.
Your ute just looks a million bucks mate.
The blue is just sensational.
More embarrassment this morning. Went for a run down for a surf rally and ran out of petrol on the way home. Same old story, gauge showing 1/3 tank. Wife came to the rescue but sitting on the side of the road for a half hour.
Easy fix,
Benda da wire !!!!
